- Joined
- Oct 7, 2006
- Messages
- 50,013
Is Mark talking in those videos?
If you let them dry with residue in them, that's what clogs it up.Funny you guys are talking about this. I’m using the same one going on 7 years. I’ve got probably 6-7 of them in the shop. NONE of them work, except the main one I use. The only thing I’ve replaced is the siphon hose, and the jug. It started to look like shyte.
All you need is a bottle of vinegar in the truck. At the end of the day, just put the siphon hose in the vinegar and blow a little through it.A buddy I know rigged up a spray bottle with a quick coupler. He leaves it full of vinegar and at the end of the day he hooks it up and sprays vinegar through his hydro force. Says it makes them last forever. Seemed unnecessary to me, but I guess he might be smarter than I thought.
Saiger" data-source="post: 4611075" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Multi sprayer brand.
Don't get the adjustable version.
Get the one with the yellow Tip in it and take that out.
Get an extra Dema valve and keep in the truck. When it goes bad you will be ready... Then order another Dema valve to have in your truck repair kit (like about every three years)
JonDon has the Multi Sprayer private labeled as Powerforce II
I am now using their new six quart version. Not sure if JonDon has on their website but a cool new feature taking out the hard inline brass tube.
Keep in mind there is a filter coming into the Multi Sprayer brand high pressure sprayer and also another filter at the end of the wand by the jet.
https://www.jondon.com/powerforce-ii-sprayer-250-1-000-psi.html
View attachment 86400View attachment 86401View attachment 86402View attachment 86403View attachment 86404
Taking out the hard inline brass tube??? Are you referring to the tube on the handle or some tube inside the dema valve?
Amazon product
https://www.jondon.com/injector-valve-complete.html
https://interlinksupply.com/index.php?item_num=NA0809A
Can you give me a good reason why there's so much of a price difference? Interlink and Jondon never gives any description of it being made in china or local american. There's a $30- $70 difference, and I've had bad luck with both. I don't mind spending that kind of money. But every 2-4months when they go bad on my end...it gets annoying. Which of the 3 is best?
Amazon product
Saiger" data-source="post: 4611126" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">I’ve never tried barker hammers products so I’ll try theirs. Thanks for the linkYes...that's what then did on the six quart units. If look in pics, easy to get to the large opening now because the rubber hose will move off to the side.
I get mine from Barker-Hammer in Minneapolis, MN.
They are just down the road from Multi Sprayer and a distributor.
https://www.barker-hammer.com/
You would have to call them if you wanted the six quart....I don't think they advertise much on their website
Barker-Hammer is a MN distributor by the way.I’ve never tried barker hammers products so I’ll try theirs. Thanks for the link
