- Joined
- Oct 6, 2006
- Messages
- 117,348
Post padding resi pile is lame but funked up olefin GD, it has some benefits...The idea of post padding was lame, but it led me into pre scrubbing back in the days just before rotary extraction. It made a huge difference in commercial cleaning.
CanadianYour face?
That's why I tell em that it takes a couple cleaning or three to correct...then checks clears and no problem. Restuarant need monthly cleaning, not 5 step cleaning process...Post padding resi pile is lame but funked up olefin GD, it has some benefits...
Id do that.I've been toying with the idea of putting down my prespray with my O.P. and scrubbing with a red pad
Use a pile lifter to agitate your pre-spray, then HWE - hot!
I get what you're saying, but the purpose of putting it down with the OP would be to hopefully save a step and time.Use a pile lifter to agitate your pre-spray, then HWE - hot!
I tried that, once at Pegs greasy Spoon, where I have tried EVERY thing at least once.On trashed carpets, shower feed your precondition through a Cimex for superior agitation then rinse with a Zipper Spinner.
Hard to equal the results and if a two man crew its actually not any slower.
You will use more precondition but if its trashed it needed it.
One man is a lot of work but still can be done. It works so much easier with two technicians.I tried that, once at Pegs greasy Spoon, where I have tried EVERY thing at least once.
Zipper still needed trimming and didn't dry as well as my 12"wands
More thoroughly rinsed with the zipper spinner sure but the regular zipper I don't think soOne man is a lot of work but still can be done. It works so much easier with two technicians.
Yes I edged when using a Zipper or Rotary. Yes it is more thoroughly rinsed that using just a wand, it may take a little longer to dry. If needed use airmovers to speed the drying.
I suppose it depends on how slowly you more each tool. I would think the regular would leave it drier than a wand. ???More thoroughly rinsed with the zipper spinner sure but the regular zipper I don't think so
definite extra soil removal, friction drying of sorts, leaving an encapymer behind to act as an anti wick/protector, until the check clears...
It was a bigger deal in the early days of the olefin era when most of us didn't yet understand yet what it was.
