Without a DOUBT!
What looks easier, the wand or the stair tool? You be the judge.
I spray out scampoo and use a hand bonnet on stairs : )
ruff
Ofer Kolton
Holding the wand all wrong.
Stand forward and reach back to the trigger.
Says the man who can go on and on and on about protecting a $25.00 valve with a cheap Chinese brass nipple, for the principle. Yet will clumsy his back and rotator cuff to clean with the wrong tool.
Makes sense.
Hack Attack
Dan
Can I do stairs with a full size wand? Yes
Do I think its a good idea? No
Reactions: roro
ruff
Ofer Kolton
In other words: Wand stairs when you don't care about the results, and a stair tool when you do?
The pictures are definitely an exaggeration. Still a clumsy tool for stairs, that does not enable one to do detail work, may increase chances of damage to property and long term not a good posture for the back and shoulder.
This is the wrong way to advertise the 12” devastator.
I think Mikey needs to make a video of a female cleaning normally with it and showing how the 1 1/2” is the perfect size for their hands.
There needs to be more women in this business
close
but not accurate
different pay scale
different production methods
FOJL
Makes sense.
I use and prefer a stair tool, genius. But if I have to use a wand I can, and can rock it.
ruff
Ofer Kolton
Well.....thank you Lee. I never had a doubt.
I'm not saying you can't use your wand on stairs, in fact, in the building in my picture, I cleaned the last 6 stairs at each end of the ground floor hallway with the wand. It's a straight shot and not too uncomfortable. On the upper staircases, it's steep and not a lot of room to maneuver especially between the last 2 stairs and the landing wall. You would have to turn a full size wand sideways to get the last 2 stairs. If you only do a few stairs once in a while and want to use your wand, go for it. If you live in the land of stairs, you're better off finding a stair tool that works for you. Power washers have the same issue. If they are always using the lance in large jobs, rather than a spinner, they have to hold their shoulder high for an extended period of time and risk doing damage to their rotator cuff. Today, I cleaned 96 stairs. I am thankful for my stair tool.
Rob Grady
Rob Grady
And one tool to rule them all. Hard to argue with 525 cleaning passes per minute
Reactions: Bob Pruitt
Rob Grady
Rob Grady
And one cleaning head to rule all RV heads.Rolls over bullnoses, can be used vertically on risers ambidextrously.
Bet you guys have never used a set up like this. Has the ss floater attached to distribution chamber.
