If you leave outside wit the heater onDoes anyone have suggestion on best heater for Truckmount when using it during the winter? I have a Thermalwave setup. Or should i just shut down and add RV anti=freeze?
That won't happen with an electric heater with a insulated van.. Heated with them for years. Now infrared propane heaters will do that due to the moisture they give off but not electric.If you leave outside wit the heater on
You have at least an inch of ice on the inside
True!That won't happen with an electric heater with a insulated van.. Heated with them for years. Now infrared propane heaters will do that due to the moisture they give off but not electric.
Just hope it doesnt snow. I sealed mine in ice on the outside one year but nothing froze inside.
Isn't it just going to output the same as all other $50 1500w heaters? 5k BTU output for the patron, 20k BTU heat output for the diesel heater.
the garage is nice and cozy warm not only for the van and equipment but also do the regular maintenance and water fill ups in the morning. Best investment if you can do it.
It just heats differently… I have one in my garage, and when I’m to lazy to take my van to the shop (after a 16-18 hr day), I throw it in the van, set in on low, and the van is a sauna in the morning…Isn't it just going to output the same as all other $50 1500w heaters? 5k BTU output for the patron, 20k BTU heat output for the diesel heater.
Is a 1500w electric heater enough though?It just heats differently… I have one in my garage, and when I’m to lazy to take my van to the shop (after a 16-18 hr day), I throw it in the van, set in on low, and the van is a sauna in the morning…
It’s built for commercial use.
It’s designed to run CONTINUOUSLY for 10 years… not like the other plastic junk on the market.
Convenience; it’s plugs into a standard wall socket (make sure it’s a dedicated circuit).
No playing around with messy fuels…
Just my experience.
You bet!I remember back in 1999 when we decided not to continue water/fire restoration services with a shop and downsize to just me cleaning out of a home (which is how it all started out) The realtor asked what we wanted in a home and the first priority was a floor drain in the garage. It was the first time the realtor heard that one! So we found our home and insulated the garage and installed a heater. Now the garage is nice and cozy warm not only for the van and equipment but also do the regular maintenance and water fill ups in the morning. Best investment if you can do it.
