Who is a MUD MAKER?
SteamwayPro
George
Nobody will admit to not vacuuming
But vacuums miss a lot
Whatever the vacuum misses a CRB gets
And I CRB twice on every job
I vacuum, then scrub with a CRB, and groom with a CRB
There is nothing left in that carpet when I'm done
Except for some moisture that will dry in 1-2 hours
I love CRB's !!!
SteamwayPro
George
If you do not pre-vacuum?
Can you explain to us why?
Thank You!
I'm thinking about buying another vacuum
Just what I need another vacuum
Oxy-Dry and Paul both like the Hoover Hushtone
I buy a lot of stuff they recommend and they're usually right
I won't buy new I will buy used off ebay
Reactions: frank fratto
frank fratto
frank fratto
They know what they're doing!!
I sure like my Sanitary with replaceable bags!!
That design has not changed for over 50+ plus years!!
It just WORKS!!............
Reactions: SteamwayPro
SteamwayPro
George
I like wasting money
And remember I'm a WHORE
I don't need another vacuum but why not they say it's good so I will buy a used one to try
I already have three vacuums on my van
The Hushtone will take the Sharks place on my van
frank fratto
frank fratto
Yes get one, then report back on the performance?
they live
Steve
Weren't you complaining about the cost of a truckmount?
frank fratto
frank fratto
I thought you vacuumed it.
Everyone should be vacuuming!? [RIGHT?]
The red pad is a TOOL!
And like all great tools,
One of it function is to Remove pet hair from carpet..
I don't know anything else that works Better?
If you do please, enlighten me I'd like to LEARN???
they live
Steve
A vacuum?
Reactions: jeffexe
I love the art and intimacy of pre vacuuming, it lets me form a relationship with the floor and dig deep into the carpets history, learning about all its owners unique characteristics and sins as I study the real soil, soul and sole wear patterns, and not just casts of light and the homeowners recent footprints..
Once you get it wet all that valuable "stuff" gets hidden and suppressed...
  • Wow
frank fratto
frank fratto
WOW!!!
they live
Steve
Steve,
After you vacuum?
A red pad pulls out stuck hair
better than anything I know of ?
Even a CRB ?
Any other solution, Sherlock??????????
So vacuuming only gets the easy stuff?
Sounds like a waste of time then.
Do you use the same vacuum job to job?
Maybe my customers are just too picky.
My wand digs out hair and mud just fine. It flushes out urine too without spreading it around room to room or job to job.
And I dont have to spend an hour a day tearing it apart and cleaning it.
Dont get me wrong I do vacuum some jobs just not every job. I spend that extra time scrubbing with the wand.
Ive noticed it does as good as the crb on most jobs too. There are exceptions though.
Detergents usually make the most difference.
My wand vacuum is powered by a 6.0 liter gm engine not a cord.it can lock down and pull carpet off the floor. In fact sometimes I do that to get airflow to help dry it.
Add 200 degree water at 5 or 600 psi for agitation and not much is left behind.
If you are not spending 15 plus minutes per small room vacuuming you are wasting your time. It would add an hour to average jobs easily. For what? Impressions?
Bragging rights?
Ive used red pads plenty to scrub in the past. Now I just use the right product.
That loaded red pad is causing fiber damage. All the sand and grit just grinding away at the soft fiber. And again cross contamination if you dont throw it away after every job.
Imagine all the poo and pee soaked into it that you never saw.
I have restaurants that I use to have to scrub to get clean. Not anymore.
So to answer your Sherlock question get a good truckmount and wand and find the right product.
frank fratto
frank fratto
Bragging rights?
Steve,
I Own plenty of truck mounts for over 30 years...
Vacuuming is not a waste of time [I think you said? That you do what the Manufacturers recommend??]
No, I do not buy a new vacuum for every job?
Sounds like to me you have Great customers??
It takes me about 3 minutes to tear apart the Sanitary??
Wand SCRUBBING???
CRB VS wand " for SCRUBBING ?? "
Detergent makes all the difference??
Suction Carpet off the Floor "omg" That's when MUD MAKERS have a problem??
If you're charging correctly, 15+ a room is part of the JOB??
Carpet fiber is very TOUGH, you Vacuum to get the Grit and Sand Out? [YOU MUD MAKER]
Using a RED PAD almost every day for 10 years, NEVER DAMAGED CARPET YET??
Red pads are very Cheap??
Yes I hope all the poo and pee soaked into it??
Steve,
Thanks for all the Good Advice!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
frank fratto
frank fratto
Steve,
No, I do not buy new vacuum for evert job?
Wand SCRUBBING???
Steve,
Steve,
By the way, Thank You for Telling us why you DO NOT VACUUM................
MarkieMark
Mark Franco
Hushtones are awesome. We have 4 of them now and they have lasted quite well so far. Made the jump from shark and it's such a night and day difference.
They jumped up in price quite a bit though, like 2 hundred more as they were going for $280-$300 at Amazon.. Had two plastic parts break here or there but all easy cheap quick fixes. Vacuum and roller difference is night/day. Also you don't have to have a dirty canister showing with the bags plus they change out maybe faster than dump and clean of cannisters.
SteamwayPro
George
$525 now on Amazon
I put in a bid for a used one on ebay for $150
I doubt seller will take offer but should be able to get if for less than $200
I get great deals on used like new equipment on ebay
frank fratto
frank fratto
Steve, what machine do you have?
Steve,
It doesn't matter?
I'm sure it's a Fine truck mount!
I hope it takes you on many profitable and fun adventures!!!
Steve,
Merry Christmas to you and your Family and Happy New Year!!!
GOD Bless!
SteamwayPro
George
$525 now on Amazon
The ebay Seller tried playing games with me and I don't play games
He lowered his price on the Hoover Hushtone to $180 but raised the shipping charge and thought I wouldn't notice WRONG
So I bought a new Hushtone for $260
Great Deal !!!
13'' Hoover Hushtone on Amazon is $479
15'' Hoover Hushtone on Amazon is $525
Shark goes in the basement and I will keep 3 vacuums on Van. All have their place in my VLM Arsenal
12'' Pro Team
Kirby Avalir 2
frank fratto
frank fratto
Great Deal !!!
12'' Pro Team
Kirby Avalir 2
George,
With all those vacuums, you will not be a MUD MAKER!!!!! LOL
