Jun 26, 2025 #1 icleancarpetz Member Joined Mar 7, 2015 Messages 1,709 Name Rafael Samson Which plier cutter you using for a clean cut right thru a solution? I use a faithful ole dremel when electric is around. But when electric is not around, dremel is useless.
Jun 26, 2025 #2 D Dwain Ray Supportive Member Joined Jul 22, 2020 Messages 1,175 I use a milwaukee m12 cutoff tool. Before the battery tool i used a air cutoff tool they both are the best at cutting wire reinforced pressure hose Reactions: icleancarpetz and Living The Dream
Jun 28, 2025 #3 Nate The Great Member Joined Mar 29, 2008 Messages 9,756 Name Nate W. Bandsaw as well..
