Vac. gauge
Able 1
My vac. gauge usually works pretty good but may once every two weeks it will read like 5 when the TM is off what causes this or do i need i new gauge?
How can i make sure the gauge is accurate?
Are you looking at that gauge because of some inferiority complex you might have?
Do you measure your pecker too?
Able 1
I look at it to know how full my waste basket is but on comercial jobs, but thanks for the help!
Keith
Oh ... you were serious? Ok then, here's a suggestion.
BUY A NEW ONE!
You know it's funny, most TM mfgs. have a 90 day warranty on gauges.....that tells you something.
Gauges are fairly important, it would be worth spending a few bucks more and putting really good gauges on a $20K TM.
Keith, does your gauge have a little rubber plug on top (rear), I'd try and recalibrate that.
John Olson
John Olson
Which ones are "really" good gauges? I haven't seen any difference in the life expectancy between the $40 ones and the $70 ones. Oh and the expensive ones are the ones that Prohem Hydramaster powerclean etc put on their machines and when they go out we just put the $40 ones on.
If there is a better gauge you haven't told me about it :p
M
Mike Draper
Check your connection on the back of the gauge and on the blower, could be loose
Able 1
It does have that rubber thing on the back, How do you adjust it?
I told the dist. that it didn't seem to be working right when I bought it and was no help.
It is the liquid filled gauge.
Connections seem good right now it showing 4 and the tm is off but before i worked today (yes I worked unfortunitly) it read 0.
