Thinking about buying a RE
The Trex Jr. build is MUCH more solid. From the handle adjustment to the stainless steel head. We went from exclusively using wands to the RV Powerwands and to the RV360i then to the Mytee Trex Jr. Everyone of them were vast improvements over the last in quality of components, usability and quality of getting the carpets clean and dry. Using the Butler system we see how much water we use along with how much we extracted back. Each one was an improvement over the other.
Again, each of the tools mentioned above were an upgrade in performance, ie; clean and dry.
Beefier comes at a weight penalty.
Can you clean half a filthy room with the 360iBH and half with the Trex Jr/BH and tell a real difference in time and end result?
When I tried one I couldnt tell a difference
Rick J
rick Jones
I recently aquired The RV 360i from an auction here. I have used it only a few times , but when I do it really kicks but. I have only use the brush head. Only on really trashed , which is why I bid on it. I wanted to see how the Brush head compared. The brush is a real difference maker I believe.
I have had and love my original two head RV. I wish that brushheads were available for it.
I find needing two hands to operate the 360 i is a little clumsy. And I realy don't change up the speed much.
And with my porty it does fine. Just as with my origingal. I have, as well, always said I use less water when using them. No need to hold the trigger open.
Let the motors do the work.
Reactions: Matt Middleton
Matt Middleton
Matt Middleton
One room no difference.
Entire house the water levels show the dryness.
Really, really. Trex leaves it dryer. I get a bit bored so I always try to tweak the equipment, office proceedures etc. The cleaning business has fit our life nicely.
Loren Egland
Loren Egland
360i is 10 pounds lighter than the Mytee and has an adjustable arm making it easy to knock out stairs.
Reactions: Mike Pailliotet
