Thermostat help
ThaBeast
Anyone know where I can purchase a 205-210 degree thermostat for a 1998 Chevy v8? I can only find the hot thermostats for 1996 and older engines.
ThaBeast
Thanks Bawb I'll give that a try. Our local NAPA closed and I've been feeling a bit lost.....
Sent from my iPad using Tapatalk while peeing in the new tech's coffee
ohh they'll SAY that it's not available...
you jus have ta find the right guy that can look it up......
ThaBeast
Let me know if you find the part # for that thermostat, sure would help me out.
i might have an old box wit the numbers on it out in the shop....i'll look!
BTW....205 is the highest i've seen
ThaBeast
Hey Kevin, thanks for the help, those are for gen I small blocks. Gen II small blocks (1997-200?) have a little hole in the bottom of the stat housing that is plugged when the thermostat opens. Have you run the gen I thermostat in a gen II block without issue?
KevinD
Kevin Dumas
Sorry, could not find a 205 for a gen II, only a 180.
Maybe when Bob wakes up he could look for that empty box.
HEY...it's only noon here....cut me a break here.......!
ThaBeast
It's long past noon now bob.....
