Surviving Cold Weather cleaning!
Mark Saiger
Mr Happy!
Mark Saiger
Surviving Cold Weather cleaning! A Survival guide and procedures to making a Living and Thriving in cold weather.
Saiger's Steam Clean Vans in the winter. A pretty common sight.
My Family has been located in Northern Minnesota and North Dakota all our lives. We have been cleaning carpets in the many environments presented to us for many, many years. I am a third generation cleaner, so cleaning in cold weather is just another day AT….I mean OUT of the office. If you want to eat and feed your families, you don’t let cold weather stop you. You adapt, survive and more importantly….THRIVE!
Here are some survival tips to help you prosper. I want to tell everyone, DO NOT FEAR THE COLD! It is not as bad as it seems and your equipment will survive. I think we tend to back off doing jobs because we do not feel like leaving the warmth of the home. You have to convince your customer and client base that cleaning in the cold is no big deal and you do it every day! Give them the feeling of confidence in your cold weather “Cleaning Survival Skills” and they are more apt to call you during “the slower months”.
So here we go….Here are a few of the things my family has learned over time and I am sure there are other great Northern cleaners that could add to this as well.
Build a survival kit for you, your van and your truckmount (or portable)
The minimum you should have in your van:
1) A shovel. You do get stuck on occasion, or it is a real nice gesture to shovel your clients sidewalk to the door. You will already have them in the palm of your hand before you even get in the home if you are using a shovel to get to them.
2) Warm Gloves, Boots, hat, coat, blankey….it gets cold out there! Every walked home in the cold after sliding your van into the ditch? I can tell you…It is cold!!!
3) Jumper Cables. If you don’t need them, you will be a good Samaritan and very popular!
4) Salt or kitty litter for wheel traction.
5) Tow strap….heavy rated…just in case someone can help you get out, or vice versa!
6) Get some traction. A good set of tires not only helps you in the winter, but also in the summer during mud season. Make sure you have the proper load range as well to carry all that extra weight. We use a Load range “E” tire. http://www.goodyear.com/en-US/tires/wrangler-silentarmor
7) RV winterization solution in case your van breaks down but you still can get some winterization solution into your cleaning systems and tools and help save them from permanent damage.
8) Portable heater that operates off small bottled propane containers….you never know. It might save you and your equipment. Cube vans, you have a big challenge so you might need more than one, two, three….units. Keep in mind that these units will require oxygen to operate, so you will need to have a bit of venting.
9) Remote starting unit for your van or 2 sets of keys. Keep things running and the cab of your van heated up.
10) 50 foot and 100 foot of non-tangle rope if you are cleaning on the upper floor of apartments in the cold.
Rope to assist getting high pressure hose to higher floors
11) Quick connector wraps if you are using shorter high pressure hoses. I really recommend for winter especially getting a longer amount of uninterrupted high pressure hose. Hoses tend to freeze at the connectors.
12) You might start freezing up your vacuum hoses. This can happen at joints and connectors. You might need to temporarily wrap connectors where leaking with duct tape, or wrap in towels. We have also found that you can sometimes freeze up with your waste filter bags….so you might want to eliminate them TEMPORARILY on a particular day this might be occurring.
If you want to not just survive but THRIVE consider the following:
1) Get a door drape to keep the cold out and the heat in. People love that you are going the extra mile to protect their home.
A door drape in action
2) Floor tarps or coverings. We use canvas tarps with a poly coated tarp on top. Great moment of truth when you tarp your entire way into the cleaning areas. PS: Use them all the time and watch how people talk about how much care you took in their homes….and don’t forget the corner guards! Here is a link for some tarps you might look at:
3) LOTS OF RAGS. You are going to be wiping up and off a lot of things in a day.
4) Build a spray connector for you high pressure hose to heat the hose before going into the home. Also have a female or male connector in your possession to keep water flowing in case you have to stop cleaning for a length of time.
5) Sticky Tabs can Really be your friend. You get the chance to prep most of your furniture before you bring in any equipment of hoses and have less of a chance to freeze up your water line.
6) Bring everything you will need to do the cleaning into the home BEFORE your bring in your high pressure water line. The high pressure water line is the LAST thing that comes into the home in the winter.
7) Do not let any of your wands, prespray units, rotary units, Spotters be outside for any amount of time at all…anything that could freeze and be damaged….WILL freeze!
8) Now that you have everything vacuumed, sticky tabbed, items moved, get your vacuum hoses to the door. At this point in really cold weather, I prefer that the suction of the hose is sucking in warm air from the home vs sit outside and such freezing cold air while you prespray with your inline pressure sprayer.
Prespraying and agitation
9) If you have a direct drive and have a protective cover lid such as our Butler Systems, we lift the lid so the cab can be heated by the heat exchanger. Those of you with slide ins, will also be able to take advantage of the running items in the cab to help heat. Direct drives can have a bit of advantage in cold weather cleaning. With a slide in, you need air to be able to help run the motor. Plan your venting via a window or roof vent with the least amount of heat loss is very important. I have cleaned with both types of units (direct drive and slide ins). I have found the direct drives easier, but again…figure out HOW TO THRIVE in what mother nature is presenting too you.
10) Add access port holes to your van so doors can remain closed and hoses can get to the job. If you are running lager hose such as 2.5 inch, you will need to access holes. There are other options for hose ports, but here is a link to the Butler units which I am most familiar with and really pleased with. http://www.butlersystem.com/pop_second-hose-guide-and-security-door.html
Hose Ports
11) HEAT UP THAT HIGH PRESSURE LINE and run to the door. Get hooked up for prespraying or to begin cleaning. If you are cleaning alone and feel that your high pressure hose could freeze up while agitating or moving furniture, put a male or female end (depending on your particular set up) on the high pressure hose, get some water flowing while it is stuffed into the vac hose. In most cases, you will not need this unless you are cleaning in -50 degrees below zero (and yes I have cleaned in this!)
Sprayer end for high pressure hose​
12) Keep moving and keep cleaning is the key to your success. It is very unlikely you will freeze up no matter the temp if water keeps moving and so do you.
13) Keep thinking ahead at all times. You will not have problems as long as you are thinking the possible problems you could have.
Remember at the end of the day, your van, and cleaning units are one of your biggest investments. Wash them off so you don’t have premature rust and deterioration.
Consider looking into the smallest garage or protective building you can get your unit into. Invest in some insulation and a means to keep the heat up so not to freeze up your source of income. It doesn’t take much to keep things from freezing and breaking.
Getting things inside will significantly reduce your heating costs and help with the success of keeping things thawed out and safe. And have a back up heat source in your facility or cleaning unit! My furnace went out last week in our garage, but with the backup baseboard heating units we had set to engage at 50 degrees, we had no damage to shop or cleaning units until we got the furnace operational later that day.
If I can pass on anything through this article is Please do not be afraid of the cold! You can not only make a living during cold months, but can also prosper! We sure wish you the best in your cleaning ventures. Keep some humor, especially when you think Mother Nature is just kicking you with everything shes’s got! Some days it will feel like humor is the only thing you can bring with you for the day, besides your gloves! Be safe and be successful!
Mark Saiger
Saiger’s Steam Clean, LLC
Grand Rapids, MN
www.saigers.com
Honestly. Right now I'm on hold until I get my sapphire back. Im actually thinking about driving to Houston on Saturday to get my Amtex and bring it back home.
GCCLee
In the Appalachian Mtns..
When Temps hit 35...we.dont leave out shop without one in our rig.
A 1lb bottle of gas...can make or break a freeze up waiting on a tow
Hit the ditch or crash and ya better know how to winterize it and pull all your gauges pretty quick
Reactions: Steve Lawrence
Dang you Fred for bumping this. Now I’m getting email alerts again.
Mark Saiger
Mr Happy!
Mark Saiger
9 degrees above zero here this morning....
It rained yesterday and thunder snow....been a longtime since I have heard or seen that ...
We were supposed to get a bunch of snow....just got cold and wet....and WIND!
Who's Hiring in a warm climate? :frown:
Reactions: Numero Uno
Andy
Doesn't Matter
To keep the water flowing I have used the Hydramaster drimaster upholstery tool, (the sapphire tool will work also locked on). Layed it out from the house to the van. As you said Mark that is the last thing you do before you start cleaning so soon as I the pressure pump is on that water is flowing.
Reactions: Mark Saiger
Andy
Doesn't Matter
@Mark Saiger You have a live solution line now I understand why you are preheating your hose. I have always just coiled my solution line and use what I need.
The spiders are hibernating in Minnesota.
Steve Lawrence
I'd sure preheat my pressure hose if I were in northern Minnesota. We even do that in lower Michigan when it's cold or hot.
Loren Egland
Loren Egland
Great information Mark. Thanks for all the work you went through to share that with Mikey’s Board. Now if there was a way to not be miserable stepping out in the cold weather, it wouldn’t be so bad. :cool:
I still remember cleaning in the Minnesota cold for 14+ years. So glad I sold out and started over in California. Never going back! :)
sassyotto
Paul
this was the door drape I used on my Apex. Still have to make one for my new Titan 575. Covers everything except radiator. cuts are made for easy access to panels. Van stays toasty warm. Never needed an ice scraper. Never insulated a van either. Only dont go out if its 10 below zero or under or if schools are closed.00q0q_6vAgTj3RPxf_1200x900.jpgIMG_0778.jpgIMG_0780.jpg
sassyotto
Paul
oh, I also use a 115 foot solution line. It just seems that when I ran 2 50 foot lines I was running just a bit short. I also knew that the couplers will be the first to freeze. It eliminates those problems and also eliminates couplers inside the door even in warm weather.
A lot of what Mark says is good information but I dont change the setup/takedown routine as much as he does. Once the hose is in the door, I just attach the wand and run it for about 20 seconds till the water gets warm. After that its not going to freeze.
Reactions: Bob Savage
