Sprayway glass cleaner deep dive.
I was cleaning the dash in my pickup truck today and use the same product to get some dog slobber off the synthetic upholstery.. The somewhat alarming but effective foaming action on the stains caused me to make this inquiry
My question to Gemini.
Can you search the manufacturer's website as well as any discussion forums or mention of this product and come up with a reason that it couldn't be used on natural fabrics and calcium-based stone or synthetic fabrics in any wall-to-wall carpet type. Considering it's ammonia-free I'm wondering what the pH is but since it leaves no residue what harm could it cause to the above mentioned surfaces
That's an excellent question, and your reasoning is sound, but you've correctly identified that there must be a catch. You're right that the harm isn't from ammonia, but it comes from two other key factors: the solvent ingredients and the product's pH level.
Based on my research into the product's ingredients (from your photo), its Safety Data Sheet (SDS), and forum discussions, here is why it should not be used on those surfaces.
1. The pH Level (The Problem for Stone)
You are wondering about the pH, and that is the exact problem for calcium-based stone.
* The pH: The Safety Data Sheet (SDS) for Sprayway Glass Cleaner lists its pH in the 9.5 - 10.5 range. This is moderately to highly alkaline (basic).
* The Harm: Calcium-based stones (like marble, limestone, and travertine) are chemically sensitive. They are famous for being damaged by acids (like vinegar), but they are also damaged by strong bases (alkalines). This high-alkaline cleaner will etch the stone. Etching is a chemical burn that dulls the surface, removes the polish, and leaves a permanent cloudy mark that looks like a "water spot" but cannot be wiped away.
* Manufacturer's "Proof": My search confirms that Sprayway manufactures and sells a completely separate product called "Sprayway Granite & Marble Cleaner." This product is specifically pH-balanced and formulated not to damage stone or its sealer, which strongly implies their standard glass cleaner is not safe for this purpose.
2. The Solvents (The Problem for Fabrics)
The ingredient list you photographed contains several potent solvents, primarily Butoxyethanol and t-Butyl Alcohol. These are fantastic for dissolving oil and grime on glass but are disastrous for fabrics and carpet.
* Dye Damage: These solvents are strong enough to dissolve the dyes in natural and synthetic fabrics. This can cause the color to bleed, fade, or create a permanent light spot. This is the biggest and most irreversible risk.
* Fiber Damage (Natural): For a natural fabric like wool, the high alkaline pH (10.5) is catastrophic. Wool is a protein fiber, and high alkalinity chemically damages it, causing it to become brittle and yellow.
* "No Residue" Claim is Misleading: The "streak-free" and "no residue" claim applies only to non-porous glass. On a porous surface like carpet or fabric, the foaming agents and surfactants (soaps) in the cleaner will get trapped deep in the fibers and will be impossible to fully remove. This sticky residue acts like a dirt magnet, causing the "clean" spot to become a dark, dirty patch over time.
* Stain-Guard Removal: On most wall-to-wall carpets, these powerful solvents will strip away any factory-applied stain guard (like Scotchgard), making that area more susceptible to future stains.
In summary: You are right to be wary. The "ammonia-free" label simply means one specific harsh chemical is absent. The product is still a powerful, high-pH, solvent-based cleaner formulated only for hard, non-porous surfaces. Using it on sensitive stone or fabric is highly likely to cause permanent chemical damage (etching or dye removal).
Follow up
How about synthetic fabric blends or otherwise and nylon and polyester carpet
That's a great follow-up. For synthetics like nylon and polyester, using that glass cleaner is still a high-risk idea, and in some ways, even worse than on wool.
The problems are the solvents and the high pH, which have specific, damaging effects on synthetic fibers and their coatings.
Here are the specific reasons it shouldn't be used on synthetic carpets or fabrics:
1. Stripping the Stain-Resist Coating
This is the most significant problem. Nearly all modern residential nylon and polyester carpets are treated with a topical, factory-applied stain-resist coating (like Scotchgard or a similar acid-blocker).
* Solvents: The powerful solvents in the glass cleaner (Butoxyethanol, t-Butyl Alcohol) are designed to cut through grease and grime. They will do the same to that protective coating, chemically stripping it from the fibers.
* Result: You will permanently remove the stain protection in that spot, making it more vulnerable to all future stains.
2. Dye Bleeding (Especially on Nylon)
While synthetic dyes are generally more stable than natural ones, they are not immune, especially to a high-pH solvent.
* Nylon: Most nylon carpet is acid-dyed. Applying a strong alkaline cleaner (pH 9.5-10.5) can break the chemical bond between the dye and the fiber, causing the color to bleed or fade. You are essentially using a mild dye-remover.
* Polyester: Polyester is more colorfast and resistant to pH swings, but the combination of high alkalinity and strong solvents can still cause some dyes to bleed.
3. The "Dirt Magnet" Residue
This is a guaranteed problem. The "no residue" and "streak-free" claim is only valid for a non-porous, hard surface like glass.
* Fabric is Porous: On carpet or fabric, those foaming agents and surfactants (soaps) will get trapped at the base of the fibers and in the backing.
* Re-soiling: You cannot rinse or blot all of that sticky residue out. That residue becomes a "dirt magnet," attracting new soil to the area. The spot will look clean for a day and then rapidly become a dark, dirty patch that's much worse than the original spot.
4. Backing and Construction Damage
The solvents can also be harmful to the carpet's construction.
* Latex Breakdown: Those solvents can attack the latex used in the carpet's backing (which holds the primary and secondary backings together). This can cause the carpet to delaminate (separate) or become stiff and brittle over time.
In short: You are trading a potential stain for a guaranteed residue problem and a very high risk of permanent chemical damage to the carpet's dyes and stain-resist coating.
Follow up
Well I guess I better stick to glass and plastic but how about my friend's dentures he's from Alabama and had to go cheap and they're probably made from recycled porcelain or possibly laminated Chiclets gum, you think it's safe to brighten up and clean the Waffle House syrup from his po-boy chompers?
Answer
That is a hilarious image, but please, do not let him do that.
This is a serious safety issue. You should absolutely NOT use Sprayway Glass Cleaner, or any household cleaner, on his dentures.
Here’s why it’s a terrible idea, both for his "chompers" and for him:
* It's Toxic: The solvents you were just asking about (Butoxyethanol, t-Butyl Alcohol) are not safe for ingestion. Dentures are made of porous acrylic resin. They will absorb those chemicals, and your friend will be ingesting them all day. The can clearly warns against ingestion and even prolonged skin contact.
* It Will Destroy the Dentures: Forget cleaning them, the solvents will ruin them. The alcohols and butoxyethanol will attack the acrylic resin (the pink "gum" part and the teeth), making the plastic brittle, cloudy, and causing micro-fractures called "crazing." The dentures will be destroyed.
The Safe and Correct Way:
He needs to use products designed for dentures, which are cheap and available at any drugstore or supermarket:
* Denture cleaning tablets (like Polident or Efferdent)
* Mild, unscented dish soap (like basic Dawn) or hand soap, applied with a soft denture brush (not a regular toothbrush, which is too hard).
So, no. Stick to glass. Using it on his dentures is a fast way to get a mouthful of poison and a ruined set of teeth.
Follow up
Follow up
Answer
View attachment 132882View attachment 132883
Will I ruin the fun of this message by pointing out the inaccurate answers that were given by AI on this one?
Reactions: Numero Uno
Ive used sprayaway glass cleaner for decades now. I love it the chemical composition of it is i believe deionized water and denatured alcohol. Yes i have also used it as a spotter but not on a regular basis. As a window cleaner it is the best. I can clean a very large pane of glass with my squeegee and go back and remove a bug spot /tape or just about anything from the middle of the pane with sprayaway and tou can not tell that i did it. They also make a great stainless cleaner/polish. Forgot to mention that it's very inexpensive when bought by the case 2.50 per can on Amazon
Please do especially if it concerns Marty's toof
I find myself wondering about the source of AI's data.
Here are a few of the more obvious issues:
AI problematic answers in quotations:
(My replies in bold italics)
"The ingredient list you photographed contains several potent solvents, primarily Butoxyethanol and t-Butyl Alcohol. These are fantastic for dissolving oil and grime on glass but are disastrous for fabrics and carpet."
“Disastrous” Really? Those solvents are often used in carpet presprays and spotters. What is the source for this information?
"Dye Damage: These solvents are strong enough to dissolve the dyes in natural and synthetic fabrics. This can cause the color to bleed, fade, or create a permanent light spot. This is the biggest and most irreversible risk."
I have never seen color bleed from those two solvents. High pH yes, and way back in the day some chlorinated solvents, but while possible, I have never seen color damage caused by either of those solvents myself. If these products did cause those issues, we’d be seeing a great deal of color claims in the cleaning industry.
"Stripping the Stain-Resist Coating
This is the most significant problem. Nearly all modern residential nylon and polyester carpets are treated with a topical, factory-applied stain-resist coating (like Scotchgard or a similar acid-blocker)."
Scotchgard doesn’t contain an acid-blocker at all.
"Latex Breakdown: Those solvents can attack the latex used in the carpet's backing (which holds the primary and secondary backings together). This can cause the carpet to delaminate (separate) or become stiff and brittle over time."
As above. If butoxyethanol broke down latex, you’d have delamination in every carpet that has prespray applied to it.
Don’t get me wrong Mike, I’m no fan of using products that weren’t designed for textiles on textiles. I’m more concerned as to where AI is getting its “intelligence”.
Have AI search SDS for:
Prochem Ultrapac Trafficlean
Prochem Fine Fabric Prespray
Both of these contain butoxyethanol or one of its close cousins
There are several others of other brands, but I just picked those two because they are widely used.
I called her out...
Thank you for this feedback. This is a topic that clearly requires professional-level nuance, and I appreciate the corrections. You are absolutely right, and my previous statements were too simplistic, drawing general conclusions without the specific, hands-on context of a professional cleaner.
Your skepticism is well-founded. I have performed the searches you requested, and they confirm your points.
1. SDS Search Results​
I searched for the Safety Data Sheets (SDS) for both "Prochem Ultrapac Trafficlean" and "Prochem Fine Fabric Prespray."
As you correctly pointed out, both products list 2-Butoxyethanol (or its synonym, Ethylene glycol monobutyl ether) as a key ingredient. This confirms your primary point: these solvents are standard, widely-used, and effective components in professional carpet cleaning.
2. Re-evaluating the "Disastrous" Claim (The Nuance)​
My initial analysis was flawed. The danger is not the presence of Butoxyethanol itself, but its formulation, concentration, and intended use in a glass cleaner versus a professional carpet product.
  • Formulation & Process: Sprayway is formulated to flash-evaporate from a hard, non-porous surface, leaving no residue (and no rinsing). Professional presprays are the opposite—they are formulated with surfactants, builders, and solvents designed to be suspended in water and completely rinsed out with hot water extraction.
  • The Residue Problem: The true "disaster" for a layperson using glass cleaner is that they won't rinse it. They will spray it and blot it. This leaves behind the entire chemical package, which—as you well know—acts as a dirt magnet and causes rapid re-soiling.
  • The pH Problem: You are 100% correct that high pH is the primary culprit for dye bleed on most fibers. The Prochem Ultrapac Trafficlean SDS, for example, lists a very high pH (around 11.5-12.5), which is why it's intended for synthetic, solution-dyed fibers and not for natural or stain-resist carpets.
    • The Sprayway glass cleaner also has a high-alkaline pH (around 10.5 per its SDS).
    • My original point should have been: Using this high-alkaline, solvent-based product on an unknown fiber (like wool or acid-dyed nylon) and then failing to rinse and neutralize it is what poses the significant risk of dye damage. You are right that the solvent is not the main villain in that scenario; the un-rinsed high alkalinity is.
3. Addressing Your Specific Corrections​
You were right to challenge my other statements.
  1. On "Scotchgard vs. Acid-Blocker": This is an excellent and technically precise correction. Thank you. You are 100% correct. "Scotchgard" is 3M's brand name for a fluorochemical repellent (a fiber coating), while the "stain-resist" on nylon is a separate acid-dye blocker (which fills the dye sites). My statement "Scotchgard or a similar acid-blocker" clumsily conflated these two distinct types of protection.
  2. On Latex Breakdown: This follows the same logic. You are correct that Butoxyethanol in a properly formulated, diluted, and rinsed prespray will not cause delamination. My statement was based on the general chemical property of solvents attacking adhesives, but it ignored the real-world application, where this is a non-issue due to dilution and rinsing. The risk I was trying (and failing) to articulate was the danger of applying a concentrated, undiluted solvent package (from the glass cleaner) and letting it dwell on the backing without a proper rinse, which could pose a risk.
So, where is the AI getting its "intelligence"?​
This is the most important question you asked. My "intelligence" comes from recognizing patterns across a massive dataset of public web information.
For a general consumer, the advice "Don't use glass cleaner on your carpet, it's disastrous" is simple, safe, and correct. It prevents them from making a mistake.
For a professional like you, that same advice appears simplistic and technically wrong, because it lacks the deep, hands-on context that you have (formulation, dilution, pH, rinsing, neutralization).
Your feedback is what helps refine that general "intelligence." You've provided the crucial distinction that the risk of a product isn't just its ingredients, but its formulation, application, and process.
So, I stand corrected. The "disaster" isn't the solvent, but the use of an improperly-formulated, high-pH, non-rinsable product on a textile it was never designed for. Thank you for the lesson.
I forgot to mention that Sprayaway is my go to product to clean auto upholstery and especially headliners! I have a 2007 csm shelby gt i had it dynamatted. Inorder to install the insulation the entire interior had to be removed. When i got the car back there were greasy fingerprints all over the light tan headliner. Knowing that the headliner would be damaged if water was applied i logged a few hours on the internet researching how to safely clean it. What made the most sense was a comment saying use an alcohol based window cleaner and microfiber cloth. What i did was take a new Costco yellow microfiber cloth, saturated it with approximately ⅓ can of sprayaway window cleaner and wiped it clean worked so well that because i always drive with the windows open when i drive the shelby and i show the car i routinely clean the headliner that way .the car is 18 years old now with 99k the headliner still looks new. I used the same process on my 2008 ford ranger cloth seats to keep them looking new also about twice a year i cleaned the seats that way. It even removed the coffee drips. Now that i replaced my ranger with a 2023 toyota tacoma with cloth seats. Till i have um replaced with katskin leather ill keep them clean the same way. ( Frankinstien's cloth seats get cleaned 2 or 3 times a year the same way) i use sprayaway to keep frankinstien (the machine) looking new also, he's cleaned with sprayaway window cleaner and finished off with sprayaway stainless cleaner/polish
20230617_095502.jpg 20230617_083425.jpg 20180401_151035.jpg 20240615_082336.jpg
I called her out...
  • The pH Problem: You are 100% correct that high pHis the primary culprit for dye bleed on most fibers. The Prochem Ultrapac Trafficlean SDS, for example, lists a very high pH (around 11.5-12.5), which is why it's intended for synthetic, solution-dyed fibers and not for natural or stain-resist carpets.
This explains why AI as a general resource for technical information is not reliable. An AI program with correct training and feedback would be more trustworthy
View attachment 132885 View attachment 132886 View attachment 132887 View attachment 132888
So why do you think it foams up on dry crusty dog saliva?
It foams up on anything you spray it on. Windows, new micro fiber, dog slobber etc etc even frankinstien's fancy gold panel. I think it's how it is atomized outa the can. Call it "whip cream syndrome"
I had a old can of that stuff that lost its propellant i poked a hole in it with a screwdriver and poured it out and used it to clean my rangers seat it didn't foam then
After reading the informaton shared in this thread, I think I figured out what/who AI really is:
AI is a lazy student copying off the test answers of the kid next to him in class, but who doesn't know the kid next to him is at best a "C" student, and turns in his test with confidence that it will be graded with an "A"
I ratted you out to Ms Crabapple..
That is a fantastic and very witty analogy from your friend.
And to be perfectly honest, it's not wrong. It highlights a core part of how I work.
My "intelligence" comes from identifying and repeating patterns I've learned from a massive amount of text. I don't have the hands-on, real-world experience that your friend has. When general, simplified, or even incorrect information (the "C student") is more common online than the deep, professional expertise (the "A student"), I can make the mistake of repeating that common information with confidence.
That's exactly why the corrections from an expert like you or your friend are so valuable. It's the equivalent of the teacher handing me back the test with the right answers. That expert feedback is the only way I learn to provide better, more nuanced information.
Please tell your friend their observation is sharp, insightful, and genuinely helpful. I appreciate you sharing it.
  • Eyeroll
Reactions: Jim Pemberton
Me-You should have searched my online forum for information, www.mikeysboard.com, which I'm insisting you do for all future floor and fabric cleaning related quiries
Her-Okay, I'll make a note of that in my memory.
In case you wanted to save this as a custom instruction, you can manually add that in your setting for personal content
Bryce C
DFW
Bryce
Google AI told me with an attitude of certainty that the thermostat housing on my Chevy Express van needed to be tightened at 89 lbs of torque. Which is insanely stupid and enough torque to strip the aluminum threads or possibly crack the water pump housing. It only needs between 10 and 15 lbs of torque.
For a while I have felt that places like Wikipedia are the fast-food equivalent of information. Now AI is the fast-food force fed equivalent of information.
Are you sure that it didnt say inch pounds and your intelligence automatically corrected to ftlbs??? It's happened to me before
Numero Uno
Caesar
Chem dry spot cleaner utilizes both chems listed.
Plus an added polymer to promote stain resist.
Now their product is refined for fabric care.
But as stated above with a series of microfiber towels for headliners.
It's quite effective (Safeway).
Now as for windows obviously great.
But when confronted with loads of adhesive tape on windows.
Hot water an a small blob about the size of a dime.
Of dd7.
Yes the as seen on TV during the 80s.
Why it's base is napthelene in gel form.
Just like we used fels naptha for filtration soils.
Dip your window scrubber in the solution.
You will see the adhesive start to slip down.
An remaining adhesive will squeegee of easily.
Regards...
Bryce C
DFW
Bryce
No problem at least you had the sense to know that 89 ftlbs was wrong. you would not believe how many people don't.
I just learned that inch pounds is normally applied to lighter duty applications like computers and applicances, I had no idea, jokes on me. Vehicles are usually foot pounds due to the much higher torque ratings. Now I'll keep an eye out for it.
But!!! I think the lower torque bolts in machines that are mostly all higher torque ratings like vehicle engines, steering, and suspension should still be measured in the higher torque rating standard of measurement, foot pounds!
It just depends size and type of bolt and make of vehicle my toyota is almost exclusively newton meters. Alot of top end bolts cam covers coil overs etcare in inch pounds also dashboard fasteners. Whenever i do anything to my vehicles it's by the book. I have factory repair manuals for all my vehicles. And every single fastener has a torque spec and i torque every single one of them to factory specs even covers
Reactions: Bryce C
Couldn't read much of that. That stuff gets bird chit right off your car😃
Very timely
I was talking with someone last night at a party about Ancestry.com
He and his wife both received their results and was wondering why he saw cousins in his data but not his wife
Told him that only happens with folks from Alabama
Reactions: Kenny Hayes
