Rx-20 head stuck...
floorguy
Utah
Doug
and a broken bolt :shock: :shock: :shock: :shock:
so this is the 2nd time i havent been able to remove the head after a long night of cleaning....
last time i used a 5/8 wrench on the swivel, and a 3/4 socket on the head nut....
well did it tonight and the fooking nut broke :x :x :x :x :x :x
lets hope it can be replaced....
sooo know how do i get it off??? and how do i keep from it locking down again??
Arizona
let me look ay some of the parts I got laying around and I will get back ay ya..........
Remember when you laughed at me for going the wrong way taking the head off??? Karma's a b!tch eh.... shiteatinggrin
Nah, that sucks Douggie... I only can say it happened to me only once and you know the outcome.... :lol:
Arizona
the only purpose of the nut is to get the star off...it is just welded onto the star....
sounds to me like to may have cross threaded the center hub...it is nothing more then cheap brass....
you go banging on that star you are going to bend it then it is going to be all out of whack...
if you manage to get it off with out hurting the star..you are more then welcome to have the hub that I got in the picture above...there is nothing wrong with it..threads are good.. and I don't need it any more...the star in the picture has a broken arm..I saved it in case I bent or broke another arm...they say you can drill out the rivets and bolt another arm on if you screw one up...never did it but kept this one just in case..you can have it also if you want it..
put some anti seize on the brass threads now and then and never transport the RX with the head on...
let me know.....
floorguy
Utah
Doug
finally got the damn thing off....
found my LONG pry bar and used it on 2 heads, so it wasnt just 1 that got the tweaking....plus had a socket on one of the under bolts for a pry spot...
anyway seems like no damage.... super lube here i come....it all looked like it was fine....maybe i need to put that small wire wheel in it again, and blow it out.....then super lube it....
Shane T
Waukesha, WI
Shane Tiegs
I'm having the base and a couple of other parts re-coated, so I took it apart yesterday. Found a considerable amount of hair and crap up around the shaft. Didn't notice it till it was apart.
floorguy
Utah
Doug
well used it since i got it off....
no unbalance in the head whew
and baby soft petroleum jelly worked GREAT...lol
had it on my truck when i was putting the radiator lines back...and coating them to help slide on....
thought hummmmmm
worked damn good :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
thought hummmmmm
I once used KY Jelly to put on a lower radiator hose on my car @ 3 in the morning... I had the KY in my glove box.... Worked like a champ!!! shiteatinggrin
Jay_wat
Skagit Valley,WA
Jay Watson
thought hummmmmm
Arizona
thought hummmmmm
for your radiator hose....yea..right...
Jim Martin said:
[quote="Nate The Great":255wpkau]
thought hummmmmm
for your radiator hose....yea..right...[/quote:255wpkau]
Ishityounot!!! I was 17yrs old... I tried water, spit, no luck.. Try it next time, when your working in a very tight and confined space.... shiteatinggrin
