rotovac tile and grout head
I was just watching a Saiger video where they were using the Rotovac xl with the tile and brush head. Does anyone else use this? How does it compare to other methods. I have both the 360i and XL. Just wondering if it's worthwhile to buy the tile & grout head for either.
How is it different from the brush head? What did Mark say? Were the results better than a turbo tool?
I don't know if it is better than a Turbo tool. There seem to be 2 options. One has a floating vacuum ring that looks like a pain to use and the other is on the XL using a newer style brush head. It's different than the carpet brush head in that it has different vacuum shoes and a bit of a rubber ring around the brush. Can use with any truck mount or portable without the need for 1000 psi. Still have to scrub deep grout lines but looks as good as anything else. I have been using a 175 and brush, then rinsing with a turbo or hard surface wand. This looks easier.
Reactions: Desk Jockey
Junk.
Round head
high profile
800 psi or so limitation
Clunky
The newer one for the XL looked interesting. Not concerned about the psi rating, more about the scrubbing power. Seems like it would be a good match with your brush glide. Can use with tools already on the truck.
Reactions: Mike Pailliotet
