Parts is parts
Ken692
Boston
Kenny
I just picked up a nice commercial Hoover Conquest, after a short time it's squealing, I think it will need a motor? It never stops and works great but just so noisy.
I see the motor is $130
Part # 43574106
Just wondering if there is a place parts are at a resonable price. I like Ivie
But don't see Hoover parts there. They had great wholesale pricing
GeneMiller
Boca Raton
gene miller
Are you sure the belt isn't making the noise. Take a second and clean it out. I use a compressor to blow mine out. You can usually tell if a belts been slipping by the way it looks.
Gene
Ken692
Boston
Kenny
The previous owner said it starts after 20 to 30 min after you use it, I have not had a chance, he said the motor has no play, I was thinking I could take the belt off and then I would know if it's the brush bearings.
Ken692
Boston
Kenny
Hoover Conquest C1810-020 Bagged 18" Upright Vacuum Cleaner
Features:
  • Wide Area One Pass Cleaning Enhances User Efficiency
  • 18" Cleaning Path
  • 7.0 Amps
  • Cloth Outer Bag with reusable cloth inner bag or paper bag option
  • Manual 6 Position Height Adjustment
  • Convenient foot activated on/off switch
  • Two Brush, "Auger-Action" brushroll
  • Super Tuff Nylon Fan
  • Shielded V-Belt helps limit downtime
  • Steel Rear Axle and Handle Bail for added durability
  • Large Object Clean-Out Trap stops debris from getting into the fan
  • Durable metal handle
  • 3-Position handle goes flat to pass under low clearance furnishings
  • Clear vinyl non-marking furniture guard protects furniture and walls
  • Long 50' 3 Wire SJT Cord for large area vacuuming
  • 26.0 lb
Ken692
Boston
Kenny
Gene
You know I see that the brush has a bearin that calls for lubricant
I used it for 40 min and not that bad, what a score under $40
