- Joined
- Oct 6, 2006
- Messages
- 117,267
- Bath tub to tile wall, built with tile and grout of variable gap widths from 1/16th to 1/4th , 4 stations of at least two feet long. Use a bath tub cut into 4 segments, use as cheap of a tub as possible.
- Two filled with grout
- two filled with latex caulk
- Granite slab counter to granite back splash with a 1/16th gap, counter portion can be small for portability but stable enough to place on a table to do demos. 4 feet long. Edge of counter needs to be standard ½ round bullnose edge. 4 stations
- Granite counter slab for demos. Preferably a tear out with hard water build up and some staining. Minimum of 4 ft. 2 stations
- Shower wall to shower wall (6x6 tiles) 4 stations
- Shower floor to shower wall 2” floor tiles to 12” wall tiles. Porcelain or ceramic. 4 stations
- MDF baseboard to tile floor, 4 ft long, 4 stations
- Spare pieces of MDF for chemical damage demos
- Bottom mount sink to countertop, Formica or any cheap available counter, stainless sink if possible. 1/8th gap, pre-filled with clear silicone, 1 station
- 4’x4’ pallet covered in 12” Porcelain tiles with a ¼” sanded grout, 1 station
- 4’x4’ pallet covered in 12” Noche style Travertine tiles with holes, with a ¼” sanded grout, 1 station
- 4’x4’ pallet covered in 12” Porcelain tiles with a ¼” sanded grout, PRE SEALED WITH 2 COATED WITH VCT SEALER, 1 station
- Wood floor samples, solid wood 2.225 Oak and hand scraped plank or any width, engineered with variable top thickness, “Pergo” laminate
- 4” to 4” Melamine planks for SGA and backer rod demos, held together with L brackets, 4’long, 4 stations
