Now it's better
jack zerkie
I have a EDIC portable that's a great unit about 5 yrs but hardly use it a 500 psi with 2-3 stage vacs . Have not used it for a while, so me bad .I always rinse the tank and run the vacs for 5 min to dry out. But I never cleaned the water filter at the rear of unit. Well it was slugged up bad slowing the water flow. So I cleaned it and tried again but I forgot to use the primer valve on the unit for the pump water flow . Now it runs like new so I will remember to do that more often. jz.
But I wonder if he has to bend over in a perverted way and see his butt in the mirror to dab at it with those wet wipes?
Well, you see, wet wipes are moist and cool and rhoid friendly when they're hanging out there exposed to the elements.
