New Bottle Shelf...Your thoughts?
John LaBarbera
Working on a new 5-1 qt. bottle shelf will sell through your local dist. for about $25.00 each. It mounts to your van door or wall. Is this something that you guys could use or am I going off in the wrong direction? Please let me know what you think. Thanks.
Insulate it and make it hold six and you'll sell a few hundred to this crowd
John LaBarbera
Why six? Won't it be too wide to fit most swing doors?
John LaBarbera
Mikey, if you could sell that many. You'll get a six pack of this. One for the hand and 5 for the shelf.
B
Bob Foster
John please make sure it drains
If you can try and make it so you can see labels through it. Maybe a relief in the middle of the round that exposes even part of a label.
Can you also combine another use with it by adding other utility to it like block holders or even a big mouth jug holder below it.
I like it
Make sure it's not too long, so a double stack 5 over 5 can used
X
XTREME1
Funny you would have that. I was saying to myself the otherday that a good durable divider would be great for my shelving. I would prefer a good divider than that unit
John LaBarbera
If you can try and make it so you can see labels through it. maybe a relief in the middle of the round that exposes even part of a label.
Can you also combine another use with it by adding other utility too it like block holders or even a big mouth jug holder below it.
Good ideas Bob. The area up above can have labels applied to it. A drain is easy. Maybe a second shelf design that held the sprayer and blocks or tabs or something would be good.
John LaBarbera
You mean like an inset for the Mytee gallon jug shelf to accommodate quarts?
X
XTREME1
yes. The shelves are great but I have to tuck my spotters that aren't in the kit between the gallons. I would prefer to have there own section
John LaBarbera
How many qt. bottles do you need to hold?
X
XTREME1
9 quarts running around
I usually have in quarts
2 Hel-Gel
1 One Step Red Relief
1 40 Volume
2 Stain Magic
1 Paint Oikl Grease
1 Prochem Solvent
1 Bridgepoint gumgel
on the other truck I have a six quart medical bottle holder I got from my wifes company on the door. It holds six quarts on one run but you can get them individually also
Ron K
Not to complicate this but make it so you can just slide it off a locking mechanism so you can just carry it in the home.
Make another one blocks and tabs scrapper ect.
Ron K nailed it.....good storage for the door but portable to carry in.......
I would let Mike buy me one like that..........
ronbeatty
Ron Beatty
John, The bottle holder is a great idea, I was going to make one out of plywood :oops: . Sign me up for four if you go with it. :mrgreen:
tmdry
Bill Martins
Looks great this can be very useful.
Being able to display the labels as mentioned above would be very important.
floorguy
Doug
2 Hel-Gel
1 40 Volume
2 Stain Magic
1 Paint Oikl Grease
1 Prochem Solvent
DAAAAAMMMMMMMMMNNNNNNN
GOT ENOUGH THERE GERTRUDE???
just use cobbs powermax and be done with 95% of crap
B
Bob Foster
The shelf could have a bootie dispenser on it. Another thing you could build John is a shoe to put your wand head in when you are transporting the van. Most of the shoes you see now are metal and will only fit 12 inch wands. A roto shoe would protect the glide.
Another thing to build if Maker hasn't done it is a wrap to protect the bottom bannister pole on a stair. This shoud be spring loaded to open around a bannister and close "clamped" under pressure on the pole or pony wall. This also could be used around the edge of a door frame too.
A got a dozen more ideas most suited to roto molding.
Where's your filter box?
dealtimeman
Everyday is Saturday.
Michael
and alot lighter
and going to last longer looking nicer
and quieter
and overall a better product!
nice john very nice! :mrgreen:
i will take four! :mrgreen:
X
XTREME1
floorguy said:
Be prepared. You don't carry any inventory on the truck for spotting? That will last me a long time.
I went through atleast 6 buckets of cobbs powermax, still waiting for my last one from last year that I ordered. It didn't mix well and clogged my sprayers etc etc and did a decent job cleaning but I had a few issues with it. Masterblend ultra TLC would kicks cobbs ass.
Not to be negative, because I really like the idea, but is too much weight on the door a concern for the hinges? Or is 40-50lb not enough to cause a problem?
We had a solution hose reel mounted to the door and the weight caused issues with the hinges.
It eventually had to be mounted on a swivel to swing from inside the van.
Also the holders would have to come high enough up on the bottles that the don't tip out when the door is slammed.
Chads
Make sure the parts that stickout dont hit peoples hose reels and make them not look as ghetto as mine look here is pic of all the crap i stuff in mine and yes there still is not enough room.
I have to agree with Greg about the powermax cloging the inline sprayer.
The Preacher
you boyz don't mix your powders first to put in a hydoforce or electric sprayer???
it's easy to mix powders into a liq concentrate, just mix an ounce per gallon till the powder won't break down anymore, then you know how many ounces per gallon of liquid to use!!!
SHAwn on Dannys computer!
There is no problem with the electric sprayer mixing. It's just mixing for concentrate for an inline. Powermax is good just not to mix up in concentration for an inline.
