Molten Plastic
Jack May
I've got this job to do. I've done a small test using a butane torch but is slow and tedious.
Adjuster does NOT want to replace anything, because that will open a whole can of worms with compliance issues, not just for this wood burner, but also for a numbe rof things in the home if we have to get a building inspector involved because of flue replacement.
He is hoping for a semi successful attempt at removing the plastic and then having an onsite company re spray the flue.
Any suggestions that may be more effective than a butane torch?
John
Jack May
Automatic fly spray unit.
I tested 4 different solvents to no avail.
Heat allows (possibly) for no refinishing, sanding will regardless require re spraying.
trying to keep my options open at this stage.
John
Jack May
Well, it's done. I used a butane torch and melted a small area at a time and wiped the molten plastic off and moved on. Basically had to do it twice, initial got 90% and then final got the last bit.
Not perfect, but it's up the the client and the adjuster to work out, he's offering a re spray of both the flue and the grill.
John
That came out great John!
You need to charge accordingly! 8)
