Linen Couch
Evets
Lady calls and says she has a stain on her Linen couch that she believes came from the dye in her sister's pants. It's on two of the cushions.
Anyone have experience removing this type of stain from Linen?
Thanks in advance!
Removing dye stains from any natural fiber can be difficult. Linen has a few things about it that makes it even worse:
1. It gets dark when wet. You might not be able to tell how well you are doing once you start applying products.
2. It resists bleaching. That means the products you might usually be successful in using will not necessarily work as well. Then, if you become impatient and use too much....BANG...they may kick in all at once and cause color damage.
If you have the skills to remove dye stains from cotton, rayon, and viscose, those same skills will come in handy with this one, as long as you understand the above issues.
Crocking from dye on clothing, as long as it wasn't wet, can be a bit easier to remove that a liquid dye stain, but this still can be a risky task to take on.
If you haven't taken dye stains out of natural cellulose fibers before, this wouldn't be the one I'd use for on the job training.
If you are convinced that you want to do this, call me:
412-751-3700, extension 107.
*Warning, I'll probably try to talk you out of it.
Just a guess and I have had luck doing this.
Dampen slightly and put a clean towel over area with some even weight on it and let it wick into the towel as it dries.
Johnny
Johnny
If you're not confident, suggest taking the cushions to a competent dry cleaner.
Why do any of you morons offer advice after Pemberton posts?
I'm a risk taker. But a little water and a towel shouldn't do any more damage than what's done. Low cost cept for gas and he might make a client out of her if it works.
I have linen furniture.ive experimented. I'm always looking for "easy" solutions. It happened at my house.
Evets
I appreciate all the suggestions and Jim's offer to consult, but I believe I'll go with Johnny's idea.
Thanks.
I had quoted her $250 (ouch)
