here is something new to (speed) dry carpets after HWE cleaning
https://www.carpetcruzer.com/
Procedure​
How Carpet Cleaning Has Changed Over the Years
1907
Portable Cleaning
Invented Mid 1907
Still used 117 years later
Results
  • Not very clean
  • Not very dry
  • A lot of work
Late 1960s
Truck Mounts
  • Introduced in late 60s
  • Most popular in the 1980s to present
Best Pro Method for past 60+ years
Results
  • Better Cleaning
  • Dryer than portable
  • Less work
  • More water pressure
  • Heat
  • Deeper clean
Early 1980s
Rotary Cleaning
  • Restore carpets with deeper cleaning with 450 agitations per minute versus 40 with wand per minute and more extraction
  • Carpets are left cleaner and dryer than wands & portable cleaning
More Heat + More Agitation = More Referrals
Now
For the Professional Cleaner
Challenger Carpet Cruzer
The wait is over, now you can dry carpets after steam cleaning. After 40 years with no real industry equipment built, The new surface-to-surface drying system is here.
Yes! You can dry stairs & carpet and solve customers’ concern for wet carpet and get paid for it.
That’s a pretty cool invention. So it’s a hot hair blowing machine over the surface??? Is that correct?
That’d be a pretty cool upsell
Ill stick with my good ole tried and true drag wand to rinse and if it needs to be dried more ill make an extra drying pass ( as i do on all wool carpets). What happens if you park that "giant hairdryer " on the carpet? Will it get hot enough to do damage?
Jh16
Alberta
Joe Rorke
Years of Experience
50
Role
Business Owner
No need to worry it is thermostats to kick off to low heat
Jh16
Alberta
Joe Rorke
Years of Experience
50
Role
Business Owner
Also eliminates the spin with customers not getting true value for topical products ie Re protecting causing over wetting and min protection because of the fear of over wetting
Jh16
Alberta
Joe Rorke
Years of Experience
50
Role
Business Owner
probably leaves corn rows behind...
Not really it lifts pile up and dries restyles with out leaving ugly rake lines also when you walk on wet damp carpet you crush the fiber down and it stays down till u rewet just like if you sleep on wet /damp hair it stays down till in the shape it dries till re wet thx joe
