- Joined
- Oct 22, 2012
- Messages
- 28,270
- Name
- Ron Marriott
It's a 2 gallon repurposed Pepsi tank. Fill the tank with solution and air it up with an air compressor. Takes up to 120 psi.What air tank do you use for the deo?
I am a padder. Sometimes.You could be a padder
Ya have a picture somewhere here?It's a 2 gallon repurposed Pepsi tank. Fill the tank with solution and air it up with an air compressor. Takes up to 120 psi.
Similar to the ones Fred posted. I'll post a pic tomorrow. I used to have a couple of 5 gallon ones but sold them as I wasn't using them.Ya have a picture somewhere here?
I used to run a small 12 v compressor on the truck. Took about 3 minutes to fill with air. I now have a 3000 inverter on the truck. I can use a full size compressor that takes less than 30 seconds to fill with air. I use a hf for prespray so this is just for Deo or protector.Be more effective if one has a air compressor in the truck.. otherwise it be junk
So you hook inverter to the truckmount battery?I used to run a small 12 v compressor on the truck. Took about 3 minutes to fill with air. I now have a 3000 inverter on the truck. I can use a full size compressor that takes less than 30 seconds to fill with air. I use a hf for prespray so this is just for Deo or protector.
Yes. I also have an isolator switch that can hook up to the truck battery as well. I haven't bothered with it. The truck mount has a belt driven alternator and a full size battery. It will power lights, air compressor, power tools, etc.So you hook inverter to the truckmount battery?
been thinking of putting an inverter in my van, get maybe 3 or 4 jobs a year where the powers off so I wouldn't use it much.Yes. I also have an isolator switch that can hook up to the truck battery as well. I haven't bothered with it. The truck mount has a belt driven alternator and a full size battery. It will power lights, air compressor, power tools, etc.
