Can carpet be cleaned with just water?
take a guess at what percentage of your next 100 jobs would come out just fine if you did everything you normal do but run just water through your pre spray and rinse or just water through your OP or Cimex?
Consider new miracle fibers, residues from DYS'rs and hacks and most importantly the power of agitation before placing your bets...
Hack Attack
Dan
10-15% if no prespray with agitation..
95% with prespray but no agitation..
It really depends on what kind of homes your business is cleaning.
Mansions? over 50%
Section 8? 0%
Blue collar? 20%ish
Doctor's homes? 0% They're dirtier than their patients.
I can't speak to percentages
"Consider new miracle fibers": The "polys" are oil loving, so I'm not sure how I feel about this one. Assuming they don't have any rug rats or greasy work/play habits, maybe.
"residues from DYS'rs and hacks": Yep.
"most importantly the power of agitation before placing your bets..." Let's add heat too Mike. Hot water changes the viscosity of oils, so coupled with agitation, you might remove some oily soils that cold-warm water wouldn't touch.
Reactions: Mike Pailliotet
jack zerkie
Some factors age of carpet and type of fibers. What has been done to carpet or lack of doing some thing.I find some time the very dirty carpets that have nothing done no resolve in carpets clean much easier and look better than the ones home cleaned.Also water will clean if there is lots of residue. Using more chems does't always help. jz
Matt Middleton
Ultra soft water makes a large difference in day to day cleaning.
I have used reverse osmosis water to clean and it does a great job. Restaurants...not so much.
RO and DI water works really well but it wastes water and is a hassle to incorporate it in your truckmount.
Ultimately you need surfactants to break down heavy soil and grease loaded carpet.
FyreLyter
Steven Dillon
I’m thinking his advertisers are slowing down on the freebies
I will have to step up my game with more hugs to alleviate that issue. My hugs cover a multitude of sins.
oh... um... I didn't just type that.
Reactions: Nomad74
DAT
Bill Cheryl
The answer is no.
Otherwise, youll condoning those z-bags...
Jim Williams
Jim Williams
I cleaned my very dirty LR this year with only hot water while trying to figure out what was making my dog itch and was very surprised how clean it came out. Cranked the heat on the LG up and let her rip. I think we could all cut back on chem usage and still have thrilled customers.
Yes just not very well at times
KevinD
Kevin Dumas
I remember once a long time ago shaking up a 5 gallon container of detergent, firing up the tm, cleaning the house and coming out to find the premeasured detergent sitting on the toolbox that was never added.
So the answer is yes, sometimes.
Ive been known to use just water with great satisfaction, especially if the last cleaning was done by a DIYer or padder.
