100% VLM ???
Condog
Tony
I’m not anti VLM. VLM/encapsulation absolutely has its place. We use it in quarterly rotation with HWE on commercial and we will often use it in conjunction with HWE in residential. Typically post bonnet.
But for residential carpet, hot water extraction should be the primary system. VLM just doesn’t check all the boxes.
I’ve had quite a few homeowners ask me about VLM after someone tried to sell them on it as “the new, better way.” I always ask them one simple question. How do you think they clean their bonnets?
They’re not spritzing them with a little encap, wiping them with a rag, and giving them a quick vacuum at the end of the week. Those pads have to be properly washed between jobs.
Once I explain that, most people instantly get why I lead with HWE for residential and only use VLM/encap as a tool, not a replacement.
They wash it in a washer which has a drain, their carpets have no drain, and I never flood a carpet, nobody should.
No cleaning method for carpet is comparable to a flood and drain system of a washing machine.
Condog
Tony
I use Procyon Plus to clean my bonnets and have used it as a rinse but don't carry it on my van
Finding hot water on the job and getting powder to dissolve is frustrating and time consuming
Much rather use liquids
When I know I'm going to need it on a job I will mix it up at home and take it with me
Hot water ready while you unload.
Reactions: jessi
Condog
Tony
Yes they are out there
There are guys out there getting paid to clean carpet just using a Oreck Orbiter and the VLM Method
That's another reason why I like OP's and CRB's
Looks much more Professional than a buffer and you get better results with a CRB and OP
A good CRB like the 14'' Brush Master Pro 35 does all the work. It has a faster brush rotation, is built like a tank and heavier than most CRB's. The added weight makes a positive difference. It makes it a more aggressive scrubber and helps it dig out all the crap the vacuum misses
I can't imagine using the VLM Method without using a good CRB
I used a CRB when I was HWE
HWE - Prespray CRB Wand
VLM - Prespray CRB OP
NOTHING beats a CRB with the right brush for scrubbing
And a CRB is CRI APPROVED. I think ???
LEESS water MORE agitation !!!
Most customers can't tell the difference between a 175 and an OP, and don't care.
Can you tell the difference between the tools used by your mechanic and a past mechanic, do you care?
Condog
Tony
Looks good for what it is, but calling that “extraction” is doing a lot of heavy lifting.
Two bedrooms, hall, living, dining on 3 gallons total isn’t flushing soil, it’s lightly dampening fibers and moving stuff around. True extraction is about rinsing and removing suspended soil, not just scrubbing in encap and wiping the tips with a bonnet.
VLM absolutely has its place, maintenance on CGD, interim cleans, etc., but using it as your only method on residential and comparing it to HWE is like using dry shampoo and calling it a shower.
I always chuckle when VLM guys use terminology like “extract.” Smear, disperse, or hide would be a lot more honest. 😄
The Jehovah witnesses will tell you the positive about their religion, the Catholics will tell your the negative about the Jehovah witness religion.
Condog
Tony
No one said your opinion isn’t allowed here. You showed up guns blazing, stirring the pot, took the first shots at HWE guys, and now you’re trying to play the victim because people pushed back. That’s not “being silenced,” that’s just disagreement.
You’re the one who dragged in the Conservative vs Liberal nonsense. Nobody else made this political. But since you went there, you exaggerated HWE as, flooding carpets like it’s the 90s, got called out, and now you’re crying foul. That tells me plenty about where you stand.
Your VLM picture doesn’t prove what you think it proves. Sure, there’s a visible difference. But is it actually clean? No. I can vacuum a hammered room and have the homeowner walk in and say, “Wow, it looks amazing!” and I have to tell them, “We’ve only vacuumed, we haven’t even started HWE yet.” By your standard, that’s done, because it looks better and the customer doesn’t know any different. Just collect the check and move on, right?
Like I’ve said repeatedly, I’m not anti VLM. We use it. It’s a tool. It has its place. It’s just not the magic answer to everything, and it doesn’t replace proper cleaning.
The carpet in your pic is disgusting. I’d hate to think there’s a baby crawling around on that, VLM clean, but I’m guessing that doesn’t bother you much as long as you didn’t have to buy a truckmount and the profit margin looks pretty.
Honestly, you’d be perfect for upsells. At the end of the job you can tell your residential customers,
“By the way, we’ve been trying to reach you about your car’s extended warranty.”
And for commercial,
“Hey, we are also with the voice activation department, and we'd like to talk to you about your Google listing.”
And when you toss those filthy bonnets into the washing machine tonight, really think about why you clean them that way, and why your customers carpet doesn’t get the same courtesy. Glad you make your customers the exception to the rule.
Lol, just clean carpet
SteamwayPro
George
Most customers can't tell is right
And most customers just want clean carpet and don't care how you do it
LESS water MORE agitation !!!
SteamwayPro
George
Saiger's code red of encap is my main go to product. On my last job I had some greasy stains of unknown origin so I mixed up a gallon sprayer of Vacaways Hot Knife. Worked great.
Hot Knife is a Dinosaur
The original Hot Knife goes back many years to the very beginning of Steve Smith and VacAway
I used it a few times when I was first experimenting with VLM
It had a bad odor but most of the early encaps had odor problems
Then I remember when VacAway came out with the new and improved Hot Knife X-Treme
I couldn't wait to try it - It cuts through dirt like a hot knife through butter
But it still had an odor
I don't know but maybe they changed the formula again since I last used it
Double Trouble with very low odor a 9.5 ph at 2 oz is the BEST encap VacAway sells today IMO
And yes I know Steve Smith sold VacAway to TMF in 2024
I love VLM !!!
I love VLM !!!
I always a little deodorizer to my encaps. Looks clean, smells clean, must be clean.
Reactions: SteamwayPro
SteamwayPro
George
For Residential I add VacAway Smart Scents Lemon Deodorizer to Double Trouble so it smells clean
Don't need to add for Commercial using Releasit. They already have a nice clean smell
SteamwayPro
George
We had 2 straight winters that were not bad so I got spoiled
We got about 10 inches of snow. I had everything shoveled and then came the freezing rain sleet and wind
I just got done shoveling and chipping 2 inches of ice and snow off my driveway and sidewalks
And the plows came by and pushed 2 ft snow and ice in front of driveway that I had to shovel through
It took me 4 hours to do that because of the ice
I have apartments to do at my Apt Complex tomorrow so it had to be done
And we might get another snow storm on Sunday
Shoveling snow isn't that hard but 2 inches of ice and snow is a workout
I HATE Winter !!!
SteamwayPro
George
It's 9 am 15 degrees and my phone is DEAD and it's going to stay DEAD
Everything is still covered with snow and 2 inches ice
That is some of the blocks of ice that had to be chipped off and shoveled off my driveway
I HATE Winter !!!
I had a business manager that would always use the term, "that's interesting ". He also said our particular plant, church was the #laboratory. If it was gonna happen, it would start there.
Latest Auctions
