Who can press new bearings on direct drive shaft?
Dwain Ray
Ya Lee....ya gotta drive the new bearing in place by laying the old bearing on top to drive it home....but you knew that..!
This is what i use to replace the bearings in my driveshafts. The aluminum spacer allows me to install bearings without removing the clutch magnet saving alot of time
All my experience is with sealed straight driveshafts. . As far as greasing goes i would pump grease same as i would on the vans driveshaft, till it seeps outa the seals unless told otherwise by hydramaster..
The CORRECT bearings are sealed and non-greasable
