White Magic blower
richd8980
how often whould you clean it?Do you do it the same way you clean the butler using soapy water or a degreaser?
Re: White Magice blower
NOOOO soapy water!
That's what yor trying to rinse out...
clear water only!
JHC!
what did i say...clear water!
There ain't no GREASE inside the case!
clear water slo stream to start...then increase stream.....rinse till blowout is clear of soap..then run to dry..about 45 sec......
then WD
soap is the enemy of blowers
Art Kelley
You don't have to do anything to them if you don't want. Just make sure to pump some grease in the two fittings once a month when you change the oil in your van engine. I used to run soapy water through my old Pro1200 and it has 12000 hours on it's second blower. My new ('03 1200) has 5800 hours on it and I have sprayed WD 40 into the blower lube port a few times over the years, but not very often.
i buy my WD40 in gal cans...i put it in a trigger sprayer and shoot three or four shots...
straight into the blower while running!
AshleyMckendree
Ashley Mckendree
20 seconds of WD will make you feel like its a vortex... untill you need to spray WD in it again!
joe harper
joe harper
Ok Rich,
Watch the OLD MANS (blood pressure) hit the roof :shock: :shock: :shock:
Soap is not the ONLY enemy of your blower :!: :!:
Actually there should be NO SOAP built-up in your blower :shock: :shock:
Soap residue can only get in the blower if the Waste Tank is full & shuts down unit :!:
Or your are cleaning a job that is FULL OF SOAP...Then you need a DEFOAMER.......
BaWB...Has NEVER seen the inside of his waste tank :oops: ..They should be cleaned
EVERY DAY..IMO...
If you DON'T do proper maintaince on your W-Tank....Moisture from the tank migrates
into your blower & causes SURFACE RUST....That is why blower can SEIZE if they have
sat for long periods of time :twisted:
OIL & WATER don't mix....Soooo as we spray WD 40 in our blowers day after day It ...
BUILTS -UP .....collecting all the dust & pollutants ect...."ever dry-vac with your unit"
WELL .......If the tank is empty all the lint & dust goes through the blower!
"Blowers don't have HEPA filters."
My point is ..You need a DETERGENT to Cut through the GUNK that builds-up & COOKS inside the BLOWER :!: :!: :!:
BaWb the "GOOBER"... is correct about FLUSHING the with clean WATER :!: ......
AFTER IT IS CLEAN :) :) :) :) :) :)
Now Joe..YOU are the PIT...
the soap is ALREADY there...
you jus need ta flush it out....
and believe me...unless yor unit sits for several weeks at a time the "dust" does no harm..
DUST????are you nuts....no dust bunnies in MY tank
HELL NO.....dust ain't no factor..
HOWEVER..yor right about not seeing in my waste tank...WHY clean it..its jus gonna get dirty again?
crazy assed youngins any way!
joe harper
joe harper
Heeeeeeeeeeeeeey.."BUDDY" you missed me ToDaY.."DeNt ChA" :p
I have had Blower a :twisted: "Lock-UP" over a Holiday Weekend..here in FL....HuMeDiTtIe :idea:
I Had one of my "FoRmEr" employees :oops:.. Go into a re-modle job & SUCK-UP
about 25lbs of "DrYWaLl-DuSt" with a empty tank :shock: :shock: :shock:
Then called the OFFice...Complaining that he had PoOr VaC....
Pulled the lid on tank..." :shock: :shock: "BUTLER" and the filter screen was MUD....
DO YOU THINK ANY dust WENT THROUGH THE BLOWER :?: :?: :?: :?: :?:
joe harper
joe harper
COME ON ..................BaWB....
I'M GeTiN-sLeEpPy....zzzzzzzzzzzzzzzz....Igatstagotobed......I'M oLd...
sPain Ta Me...how that DuSt dIDnt go In my BloWeR :?: :?: :?: :?:
Chris A
Are you off your meds?
JOE... yOus pRoolY GotS sOm kINna chEEp Filter On yOR mAChInE...
YouS ShOulD SwiTch tO a STEAM GENIE fIlTer......
joe harper
joe harper
bAwB......
We use in-line-filters....The factory Butler bags are a PITA :!: :!:
This genuis put the in-line filter on .....AFTER his sucked-up the DRYWALL :roll: "BriLLiAnT"
The pavement under the exhaust-silencer "looked like TONY MOnTaNo'S DESK :shock: "
chris:Iam sharing my "meds"......with BaWb :lol:
Them that duNO..
dunO that.....
they duNO!!!!!
joe harper
joe harper
BUT.........
what if they doNO???
That yu nO....
that they doNo......
how WoOd ...weNo!!!!!
