The new Fjord King-Cross American joint venture porty.
You'll be a hit at your neighborhood lobster boil with this baby. And just think of all the extra add on services you be able to drum up by offering to move refrigerators, china hutches and grand father clocks!
Enterprise Portable Truckmount Extractor
Your Price: $6,995.00 $3,799.00
Guaranteed: We will beat their price!
Estimated shipping cost: $ 164.00
Enterprise Portable Truckmount Extractor for only $6,995.00 $3,799.00
Steambrite's price on the Tile & Grout Extractors - Enterprise Portable Truckmount Extractor [SBMExp] is $6,995.00 $3,799.00.
If you can find a lower advertised price on the Enterprise Portable Truckmount Extractor [SBMExp] - SBMExp, contact us at 888-274-9500,
and we will beat their price! Guaranteed!
freshwater tank truckmount ebac commercial dehumidifier Steambrite MFG carpet and rug cleaning equipment and supply air conditioning equipment system cleaning carpet deep cleaning machine Truckmountscarpet extractor portable carpet cleaning machine to buy Steambrite MFG munters dehumidifier gun safe dehumidifier amana dehumidifierchemical cleaning etc pressure system whol Steambrite MFG chemical cleaning etc pressure system whol carpet extractor self Steambrite MFG air duct cleaning new jersey truck mount carpet cleaning machineair cleaning duct equipment used compare carpet cleaning machine used carpet extractor home carpet steam cleaning machine cleaning equipment rental boiler chemical cleaning Steambrite MFG dehumidifier Steambrite MFG carpet cleaning equipment manufacturer rx20 hydramaster
This is the first extractor that has four 2 stages vacuum motors (8 stages total) that has each pair of vacuum motor in series and then those to sets of pairs mounted in parallel. With eight stages of vacuum, this provides the best vacuum performance with both high CFM and High inches of water lift (12" of mercury). The machine can product 33,000 vacuum units (maximun CFM X Maximum Inches of lift = Vacuum units). You can also operate the vacuum motor pairs independently so if you want to only use only one set of motors because of shortage of electricity. This unit can operate on two, three, or four 120 volt 15 amp power cords or on 220 volt electric drier outlet. Electrical converter is provided as well as three detachable 50 ft 12-3 power cords and one 50 ft 220 volt 10-3 power cord. You can even plug your machine 100 ft away from your electric drier outlet by using the 220 volt power cord first and then run your 12 gauge extension cords the last 50 ft. Whether you want to pressure wash, clean tile floors, water extraction, auto detail engines or interior or just clean carpet and upholstery, or even air duct cleaning - this machine is the most versatile extractor on the market today. The dolly and vacuum system weight 104 lbs, the water pump weighs 65 lbs. These machine are custom made so allow up to 4 weeks for delivery. 6 months, 0% loans with no payments availible.
Includes:
# 20 gallon waste tank
# 33 gpm auto dump for dirty water for non stop cleaning
# 115 ft of vacuum and 3000 psi solution hose (100 ft of 2" and 15 ft leader of 1-1/2")
# Adjustable 1200 psi Pumptec pressure washing system, pressure washing lance, faucet adaptor, pressure washing hose, 2000 psi pressure gauge.
# Stainless steel dual jet carpet cleaning wand with assist handle
# 4-1/2" wide auto detail, stair, and upholstery cleaning wand
# Hard surface floor wand.
# 25 ft of 1-1/4" auto dump hose
# A complete 220 volt converter system (50 ft 10-3 cord, and converter box - alows you to operate the complete system off your customers electric clothes drier outlet)
# Enterprise Vacuum System w/ detachable dolley
# 2" vacuum port
# Waste Tank dirty water filtration system
Two 50 ft 12-3 power cords for the enterprise, one 25 ft power cord for the 1200 psi water pump (if equiped), and one 25 ft power cord for heater (if equiped)
Options:
For 10% to upgrade the warrantee from 90 days to 1 years parts
# For 20% upgrade the warrantee from 90 days to 2 years parts.
# Optional 1500 psi Cat pump for only $250 more
# 10" wide full size Stair wand $150
# Air duct cleaning attachment with dust downer $599
# 10 pound bag of potatoes-$5.99
# 1 pair oven mitts-$2.99
# I Maine Lobster- call for market price.
* Now availble-- More options for less money:
Model 15-6-450AD. 15 gallon waste tank, internal 450 psi water pump direct connect, Dual 3 stage vacuum in parallel, 33 gpm auto waste dump, 25 ft 1-1/4" dump hose, 25 ft 1.5" ID / 3000psi hose set, 50 ft power cords, dual jet wand, $2299
* Model 20-8-0AD. 20 gallon waste tank, quad 2 stage vacuum (2 series pair- 8 stage system), 33 gpm auto dump, machine only $1899
* Model 15-6-450ADHH. 15 gallon waste tank, 33 gpm auto dump, 25 ft 1-1/4" ID Auto Dump Hose, Dual 3 stage parallel vacuum, 450 psi internal pump, Vacuum motor exhaust heat exchanger (140 degrees), 2000 watt electric heater (210 degrees), 75 ft of 1.5" ID vacuum hose, 75 ft 3000 psi solution hose, faucet adaptor, Triple 50 ft 12-3 power cords, Dual Jet Stainless Steel Wand - $3095
* Model 2020-8-450ADHH. 20 gallon waste tank, 20 gallon fresh water tank, 450 psi water pump, 8 stages of vacuum, 33 gpm audo dump, exhaust motor heat exchanger, electric heat exchanger, Machine can heat cold garden hose water to 165 degrees F - 100 degree temperature rise!!! $3598 (cords, hoses, wands, extended warranty extra)
* $500 add vacuum exhaust heat exchanger to any model with an internal water pump (heats water to 140 degrees F - used when hot water is not availble like for garden hose hook-up.)
* $300 for fresh water tank to any model (200 and 450 psi internal pumps only)
* $175 to up grade the vacuum from 6 stages to 8 stages (only availible in 20 gallon tank)
* $250 to upgrade the pressure on 500 psi models to 1200 psi external pump.
* $100 to upgrade the 25 hose set to 50 ft hose set
* $175 to upgrade the 15 gallons to 20 gallon tank (required on 8 stage systems)
* 220 volt to 110 volt 4 gang Converter $165 (for 4 cord machines)
* 220 volt to 100 volt 3 gang Converter $133 (for 3 corded machines)
* 220 volt 10-3 extension cord $110
* Sink mount 2000 watt heater with 200 psi pump auto fill system $825 (turns your flood pumper into a carpet cleaner)
* External 1200 psi Water Hog pump with pressure cleaning lance $799 (great for tile cleaning or turn down the pressure to 500 psi for carpet and upholstery cleaning
* $125 for 500 psi internal spray hand tool
* $300 for 1200 psi 14" wide brush lip tile wand.
* External 2000 watt water heater $349
* Internal 2000 watt water heater $400
* 450 psi internal pump $650
* Heater tray for mounting heater on top of Water Hog $49
* 50 ft vacuum hose and solution hoses sets $159 (please specify 1-1/2" or 2" ID)
* 50 ft 12-3 power cords $36 each
* 12" Dual Jet Carpet wand with assist handle $189
These are examples of what you can do, pick the tank size and what features you want. The $3799 package has more hose, 2" hose, shipping, converter, 220 volt power cord, and more tools. Please email us if you need more explanation and we will update this web page some more. Machines are custom made, so please allow up to 4 weeks for delivery.
13 Page Intensive Owner Manual
If a guy seriously spend nearly $4K for that (or is it $7K) he's surely got a few concerns in his "healthy" business to overcome.
Are there really that many new guys coming in each year? Is there a never ending list of suckers flipping through CleanFax?
And....why on earth would you buy a machine without firing it up first?
Someone used to sell something like that in cleanfax years ago.
For the apartment hacks I see no reason why you couldn't go out and get a 55 gallon barrel and mount two vac motors on top.Mount the pump on the side.After all portables only contain two vac motors and a pump.
The real suckers read Small Business Opportunities and Entrepreneur Magazines. That is where I learned about "Dry Foam Extraction". :shock:
Shawn Forsythe
More like a TAMCO
Terry's
Awesome
Machine
COmpany
Here's the Opti-Odin Vac Booster
http://www.***************/store/images/Octavac.jpg
