The Apex Vs. The Titan 575...Which one would you choose?
Both of them seem like a solid work horse. I've used the Titan myself, and I love that setup. But the Apex has a strong back also. Who's used both? Or who had to choose between the two and why did you choose the one over the other?
laura@legendbrands
Whipper Snapper
Laura O
Laura Ortbahn also with Prochem, she won't lie to you...me yes. You no.
:biggrin:
Hey now Cowboy. I never lie. I may not be nice. But I keep it real, son. (Insert hipster voice).
@Matt Wood give me a call if you have any questions for a pesky used car sales (wo)man as @Desk Jockey likes to refer to me as. Your question was directed to owner / operators and I have may have a sliiiightly biased opinion on which model I prefer ;)
Thanks for reaching out to give me your input. I couldn't see your digits in this reply, so here's mine 706-491-7530 . I'll be on the road after 9am eastern time and should be able to chat all day.
Reactions: Total_Rookie
Glynn
I have a Titan 575, its now done almost 4000 hours, it has NEVER broke down & it has never had any faults apart from a them pump diaphragm.
It hasnt even had the belts off or even adjusted yet .
The heat is the hottest Ive ever seen on any truckmount.
It never dumps any water and has a full divert system inc blower exhaust.
If I were buying another machine it would definitely be another 575.
The el Diablo , PC 650 , SS 870 and Aerotech were all 20 degrees or more hotter at the wand. Still in it's range it's awesome. Without an alternative heat source.
ruff
San Francisco, CA
Ofer Kolton
Most beneficial path, is to go to the service department of the dealer that sells both and ask which ones comes back the least for repairs.
Dependability, in my book, trumps all the minor differences in water recovery and temp.
But then.........I've never been a glorified janitor :winky:
My service dude is cheering for the Titan.
Glynn
Why would you want a machine with old HX technology that dumps water all the time when you could have a dump less system, meaning your fresh tank is effectively bigger and you can carry less weight due to not needing as much fresh water ?.
Reactions: SamIam and BIG WOOD
Mark Saiger
Mr Happy!
Grand Rapids, MN
Mark Saiger
Here are those temps I have in my planner
Everest 12 flow 210
6 Flow 225
Butler 12 flow 185
6 flow 200
El Diablo 12 flow 210 fuel fired
6 flow 240
Cleanco 12 flow 175
6 flow 190
Sapphire scientific
370 12 flow 120
6 flow
570 12 flow 185
6 flow 210
1200 SE 12 flow 180
6 flow 200
870 12 flow 225
6 flow 230
Aero tech
12 flow 250
6 flow 248
Hydra Master 575
12 flow 195
6 flow 170
Hydra Master direct drive 220 12 flow with their gauge
12 flow 175
6 flow 180
Hydrmaster 423
12 flow 150
6 flow 185
Nampa, ID
Todd
6 Flow on the Titan 575 is only 170 ? The 370 holds arounds 190 with 6 flow.... 400 PSI
Interesting. I would like to see the same chart for actual CFM testing.
Were you constant on or using on / off like carpet cleaning normally is ?
No other machine drops when going down someone needs to say maybe something is off with that.
Every 575 Titan Ive seen will hold at least 230 on 6 flow during normal cleaning, its the hottest .
I think that was either a type error, or a titan that had a bypass problem when it was shooting less water. When I used a titan with my mach12 at 6flow, I was reading 220 at the wand at 500psi. I never used a 12flow, so I couldn't tell you what that read
