Promaster Fuel Tap
LCCFL
Apopka, FL
Eli Rodriguez
I purchased the 2018 Promaster 2500. How do I know if there is a fuel tap on it? Transferring my prochem legend gt over from an express. TIA for your help.
There is a built in fuel tap. The tank is located under the drivers seat. The tapped tit has a cap on it. I’ll try to find the pic for you.
89408
clean image
Orlando
Carl Maddock
depends if you have fuel injected motor and need a return. Also legally, you may need a placard on driver door indicating the tap active.
--if you need a return you can buy a kit or...
