Permanent granite sealer
We were told our new countertop would never need sealing. Is this true?
Many forms of Granite are totally unabsorbent to water, grease, oil, solvents.. you name it ..
you can test yours by putting a tablespoon of water and covering it with a tupperware for 24 hours if the water still there at the end of that cycle you have permanent naturally sealed granite
If the water is gone and you have a dark wet spot, than yes it'll need sealing.
there are there are some Steelers out there that claim to be lifetime or permanent but that's only if you never clean the surface or subject them to UV or look at it cross-eyed if it indeed need sealing periodically try and do it at least once a year yours only neutral cleaners and don't let grease and oil and bacon fat and bong water sit on the counter for any period time
Reactions: steve_64
clean image
Orlando
Carl Maddock
Ill add you should also test with oil. However you would want to test on a scap piece.
Often the wate/ oil test , even 15 minutes, before buying lets you know what your getting into
Reactions: steve_64
