- Joined
- Sep 25, 2007
- Messages
- 5,475
- Name
- Chris
What's your process currently? I know this has been beat to death, but we're finally starting to get some calls for it. I've seen Stanley's recent add showing them using a hard surface wand
I always hand clean the seams on sheet vinyl because installers often don’t seal them properly. LVT and wood I just clean right across them. Use your best judgement regarding pressure. If your judgement has proven itself to be poor, then stick to carpet.Do you mark the seams and avoid them or change your procedure?
thoroughly dust mop or vacuum firstOk so assuming I go with a 175/gekko wand combo, then questions are
-pressure?
-red/white/blue/maroon pad?
-favorite cleaner?
- what do you look for before you start?
