Genesis ZXT powerclean (rpms jumping)
DavePCM
Dave Dilyard
Hello, I have a Genesis ZXT Powerclean that has a problem with the rpms going up and down. Truck mount will be on, It will be idled and then rpms start to pulsate between 1500 to 2000. I am currently starting to dig into it and trying to see what I can find. Although, I do not have much experience with this system. Has anyone else ran into this issue? Any suggestions or information would be greatly appreciated.
Does it have a governor on it? The old Nissan's used to have a governor that need an ounce of oil periodically. If never oiled it would do similar to what you're describing.
Where's RW when you need him?
I heard Hiltz bought his Power Clean for a song..
I personally would take a can of carb clean and start giving small squirts around the intake manifold.. It sounds like a vacuum leak to me as well but idk that machine.. The guys I remember who had those machines don't frequent the board as much.. Ash Mckendree, PowerClean Frank Perez, Doug Cox, Robert Hodge?!?
KevinD
Kevin Dumas
If you need to chase down a vacuum leak I use a propane torch with a hose attached to it.
UNLIT of course.
So a little birdie said:
My first guess on the issue would be the potentiometer (Speed Control). Pass it on.
BTW- I believe I have. Potentiometer if needed. Let me know.
