Church needs heated carpet cleaner recommendation
JonathanC
Jonathan
Role
Consumer / Homeowner
Years of Experience
1
Our church is looking to buy a commercial quality portable carpet cleaner/extractor. Something heated. Our largest space is our auditorium of 2400 sq. ft. We then have smaller spaces (fellowship hall, classrooms).
What specs should we aim for? 10 gallon cleaner and then recovery capacity? 100psi? Any other specs that would be important.
AND, any recommendation as to what we should buy. I see alot of Mytee equipment online.
Thanks!
That's what you should buy then. You can have it cleaned with less headaches of storing it, buying chemicals, spotters, blah, blah, blah.
Most here would tell you from decades of experience that typical church carpet and soils respond best to a Low Moisture system, preferably a Oscillating Pad machine with a two to three pad type system.
Modern Oxygen powered encapsulant shampoos are a true blessing for your situation'
AI Mikey has this to say...
Why Churches Should Use Oscillating Pad Machines with Peroxide Encapsulation​
Instead of Portable Hot Water Extraction (HWE)
1. Quieter, Cleaner, and Less Disruptive
  • Churches often need cleaning between services, classes, or events — sometimes during choir practice or Bible study.
  • Oscillating pad (OP) machines are quiet and low-profile, perfect for that kind of environment. No loud vacuums or fans required.
2. Faster Setup and Easier for Volunteers
  • OP systems are plug-and-play — no hoses, no water tanks, no hunting for janitor closets.
  • Volunteers and custodians can be trained in under 10 minutes to safely and effectively clean.
3. Grape Juice: Public Enemy #1
  • Let’s be honest: grape juice doesn’t care about your sermon — it stains.
  • Add coffee, wine, punch, sugary snacks, and tracked-in dirt to the mix and you’ve got a full-blown stain baptism.
  • A peroxide-based encapsulation cleaner breaks down organic dyes (like grape juice) and leaves no sticky residue to attract future dirt.
  • Unlike HWE, there’s no wicking from the pad below — what you clean stays clean.
4. Dry Fast = Safe & Convenient
  • Carpets are dry in 15–30 minutes, so the youth group can be back in without the risk of slips or mildewy smells.
  • No need to block off rooms overnight or leave blowers running all night on church power.
5. Ideal for Church-Grade Carpet
  • Most churches use low-pile glue-down carpet tiles that are easily damaged by overwetting or repeated aggressive cleaning.
  • OP + encapsulation is low-moisture, safe on seams, and removes long-standing detergent residue left by portables.
6. Microfiber Pads = Deep Clean Without Deep Soak
  • Microfiber grabs more soil and leaves carpets looking brighter.
  • When rotated regularly, they prevent cross-contamination between sanctuary, classroom, and office areas.
7. Peroxide Encaps = Odor Control + Brightening
  • Breaks down bacteria, body oils, and allergens, and naturally whitens traffic lanes.
  • Leaves behind a clean, fresh smell, not a chemical funk.
8. Better Stewardship: Time, Money, and Energy
  • Less water. Less electricity. Less chemical.
  • Fewer re-cleans or emergency spot treatments.
  • Volunteer-friendly, and easier to delegate with confidence.
🙌 Final Thought​
For most churches, switching to an oscillating pad system with peroxide encapsulation is a blessing in disguise — more efficient, safer for your floors, and built for real-world church messes, including everyone's favorite purple challenge: grape juice.
🙌 Bottom Line​
Encapsulation with an oscillating pad is faster, quieter, safer for the carpet, and costs less over time — especially in churches with tight budgets and limited staff. It's not about cutting corners, but rather choosing smarter, modern methods that align with the real-world environment and needs of church facilities.
Buy one that you would like to own. Chances are it will get used a couple of times, then sit in the janitors closet for a few years. You can then buy it at a good discount.
Reactions: Kenny Hayes
Thanks!
Let’s bring out some facts. Have you tried pricing hiring a professional to clean it with a truck mounted machine? If so, how much was it? Keep in mind, going this route is only 5% the cost to replace.
Then factor in the time it would take for you to clean it on a weekend. How much are you worth per hour.
Now, is it good to have a small machine to maintain spills? Yes.
-karcher and Mytee have some smaller machines for spot cleaning, but I don’t suggest taking this route to clean all of it.
SteamwayPro
George
This is a fantastic video. It's for Heavily soiled TRASHED CGD using the VLM Method or HWE
If your using VLM and the carpet isn't TRASHED and your just dealing with a lot of coffee stains just skip to the last step and use Hydrox
If your using HWE ( TM or Portable ) using Hydrox as a last step will help with wicking issues
View: https://youtu.be/FxxDQW8vokA
  • Love
they live
Steve
I would look for a local janitor supply store to see if they have a system and products to fit your needs. They can give you assistance without harassing you.
I wouldnt buff areas that kids play on. You are on the right track about extraction and a portable with a little practice can accomplish your needs at the price of one cleaning.
Practice in less used areas first maybe and keep feeling the carpet to see how dry you are getting it.
Its not real difficult if you take your time.
Reactions: bob vawter
Ya and don't talk to strangers.......
Kamil Tuma
Role
Years of Experience
20
Thanks!
There is plenty of equipment that can do the job. Your best bet is to check if your local city government (park and rec) has a machine you can buy cheaply. When I first started my company, we did that and found a few that helped us get off the ground. They work really well because the employees have to clean them out, lol.
