Carpet cleaning
aututo45
Mike
Role
Consumer / Homeowner
Years of Experience
12
I was not sue if I should start another thread on removing stains. This is a different type of stain. They are basically dirt marks and other hard to describe what they are. They seem to disappear and come back . The dirt stains really never come clean. I have a Bissell carpet clean I think its called a green machine. Have a steamer made by Mccullough I think paid under $200. I have tried folex stain remover, the various Bissel cleaner such as extra strength pre cleaner max pro carpet cleaner, something you add to make the solution stronger and various other top rated products through amazon. Some times if the stain is not that heavy it comes clean. If the stain is heavier it does not really come clean only lightens it. Recommendations what ele to try. Thank you.
Did you put any chemicals on the stains to treat them? Did you mix any chemicals in your bissell?
If you answered yes to any or both of those questions, put just straight water with a little bit of vinegar in your machine only to neutralize the dried chemicals on those spots. Then rinse the heck out of those areas and when you see no more bubbles going through the tool, do about 10 dry passes until no more water is extracted.
Once your'e completely finished doing that and if the spots are gone, fold several paper towels and lay them on the spots with a book on top. What this does and helps with is drying the carpet and if there's any more soil in the carpet, it will wick into the paper towels so it doesn't stay in the carpet, therefore preventing the stains from returning.
If you still see spots after the rinsing process, you need a product like awesome all purpose cleaner. Spray it directly on the spots (If your carpet is synthetic and not wool). Let dwell for about a minute. Then repeat the same rinsing process above
If you still see spots after that, call a professional
Power gel
aututo45
Mike
Role
Years of Experience
12
Do you have any photos of this particular issue and are you a consumer or a professional?
Not a professional. If photos would help. I could get them. Not that good with taking photos. Thank you for your help.
aututo45
Mike
Role
Years of Experience
12
I did not use professional chemicals or anything to mix. Used what ever amazon had that had the highest rating rating . On certain stains they work but others they don't really clean only some what lighten. Carpet couple of years old and tried frequently to keep it clean. Thank you.
aututo45
Mike
Role
Years of Experience
12
Power gel
Read about power gel it same i need an extractor, I do not have . It is a yellow and red bottle is this you are referring to? It looks like a gallon bottle red yellow 42$. Thank you.
Yeah I assumed you said steamer from McCullough and I thought you meant an extractor from Mccalla janitorial.
Definitely need something to extract rinse with.
Or get some of Mike's special encap spotter and pads
they live
Steve
For spots that come back reclean to dampen it then put a damp clean towel over it preferably a white towel then add weight so it makes good contact and just let it dry. The spot should wick up into the towel.
For dingy areas clean the brush roll on your vacuum with vinegar and water. Leave it damp and run it over the area and repeat. You can use peroxide too if its polyester.
