- Joined
- Aug 9, 2012
- Messages
- 11,570
- Name
- sam miller
You can disconnect the the harwell push a penny into the connector on the machine side or use a jumper the penny is basically a jumper and Uyour machine will run.The Harwill floats are the weak link in my system. I've replaced them more times than I care to count. The magnets get weak over time and they just stop working. I've done everything to try and extend their life, but when they want to go bad, it's a downward spiral. You may get a Dead-Cat-Bounce out of them, but they will die. I really wish there was a better answer for this. The floats are stupid expensive. I've tried to replace them with cheaper floats and some adapters, but couldn't get them to work, so I went back to the Harwill. Right now my High-level float stopped working so if I forget to turn on my APO I'll have water shooting out my blower. I call that my "Third Float"
Love my TM, I can deal with weak floats. I would do it again in a heartbeat.
There will be no automatic shut off but you'll be able to clean
